First of all check ,make sure water valve to washer is turned on. Next take off water hose see if screen is clogged and at same time make sure water is coming through the hoses to the washer. But most likely the problem is the water valve that your hoses screw on. This valve has a electric magnet control one for the hot and one for the cold. Sometimes just one side will burn out and only cold water will run in or maybe just hot will run in. But no matter witch it will need to be replaced and it's easy to do. Just unplug the wires take out the screws and pull it out and put the new back the same way
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
SOURCE: water leaking from water output at top of washer
soundsas if you have a faulty, inlet water valve. your model is notshowing up on my part look ups, but definatly replace the valve( your water hoses are connected to it. in mean time make sure to turn off water inbetween loads
SOURCE: Water continues to fill the tub even when the
This is symptomatic of a malfunctioning (not closing completely) water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs replacing and a service call ;-0(
Good luck,
John C
SOURCE: water runs right threw it never filling up and the
check your belt bur removing the rear panel and check your pump it should be underenieth next to the electric moter u can get most replacement parts at your home depo or lowes.
SOURCE: Washing machine won't stop filling the tub when I
The problem is the pressure switch has failed or the hose is plugged up, has a hole in it. These are usually inexpensive and are very easy to replace. Here is a video this will walk you thru testing and replacing a pressure switch. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
