model zsbp-002 shows error message 3 after it starts and runs for only a few seconds. there is no info on error 3 in the pamphlet.model zsbp-002 shows error message 3 after it starts and runs for only a few seconds. there is no info on error 3 in the pamphlet.
You can't post conmments that contain an email address.
No, it is not able to be calibrated by the user. If your arm is too large for the cuff it will read high. Most cuffs are made for small framed people. Try wrapping it around your lower arm and position it about 2-3 inches above the wrist. use the wrist to take the b.p.
The "60" number reading that came onto the screen was your pulse rate. If you can't get the monitor to check your blood pressure again, you may need to replace the batteries, the charge may be too low in them.
Generally, the recalibration has to be done by the manufacturer, as the calibration has to be certified. Most manufacturers charge little or nothing for this service. Contact the number in your Owner's Manual concerning how they want you to send it to them.
Valorie, you will need to return it to the Manufacturer for re-calibration. You should find the necessary information in your Owner's Manual. Contact them first, thru their Customer Support number and they will advise how you should send it in to be re-calibrated.
If the manufacturer is HoMedics, their Customer Support Number is 800-466-3342.
A monitor using Hg is only a valid monitor reading. Most electronic devices produce approximate results and are mostly good for taking several readings daily and obtaining a mean daily BP. Device calibration appears to be not accessible to the the user.Also, depending on age & condition of your dad, sequential reading must take place after elapse of enough time for circulation to be at steady state in the arm again, or if you immediately after a measurement make another, even with the same monitor you will obtain a different result.
