Vizio VW42LF 42 in. LCD HDTV Logo
Posted on Mar 08, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 42" Visio
Anonymous
Level 3:
  • Master 325 Answers
  • Posted on Mar 08, 2011
Anonymous
Master
Level 3:
Answers
325
Questions
0
Helped
67407
Points
1013
I would try to look on the power supply first for popped capacitors that supply the 24v rail for the backlight inverter.
Having sound is a positive when it comes to repair. This means that only your screen is not lighting.
If you repair the 24v line and check the 5v feed also going to the BN_on (on) the backlight inverter and you still have no picture...you will need a new backlight inverter.
Hope this helps! Please rate!
Why my 42" sanyo DP42841 HDTV LCD SCREEN GOES BLACK ON THE LEFT SIDE?
That sounds like a faulty LCD panel tab. The only true fix is to replace the screen. This usually isn't cost effective.
We gave lost the remote for our Vizio 42" HDTV.
By manual I guess you mean the buttons on the TV and not switching the actual cables. my recommendation is to get a good new universal remote. My personal preference for my Vizio TV is the Logitech 650. Just know that you program it on a computer. It controls up to 6 devices (TV, DVD, Cable box, audio and more), is easy to program with no codes to enter. I am sure it is easier to get then a new Vizio remote though a little pricey at $60.
Hope this helps,
Cullen
1helpful
I have had my Visio 47" for 3 years. One night the screen just went blank. I could not turn it off with the remote. I manually tuned it off. then used the remote to turn it on. The Visio light and...
it sounds like you need to purchase a new video board from vizio which is expensive. upwards of 600 dollars. walmart has vizio 42 in and 47 in 1080p models around 500 dollars on sale this weekend. hope this helps let me know!
No Sound on 42" Visio
The easiest thing to check for is the mute button isn't activated. IF that isn't it, you might want to go thru the on screen menus and check under the audio tab. Make sure it is selected to "on" in menu. Let me know what you fine...Good luck Sincerely HDTV GURU JAY
My vizio 42" lcd hdtv when i turn it on half of my
I have the same TV with the same problem. I'm getting tired of hitting it.
I have been told more than once that if you usa a "Visio" LCD TV in a hot area, such as near a window that gets a lot of sun, they will ****-out. Very sensitive to heat is what I have been told.
I would like to know what to do other than chucking the POS in the trash and buying a new LG.
Cable is working. I have sound but no picture
you need to buy another screen or you was tilt(plays only radios)or sound programes
1helpful
Black box in upper left of screen
Thats the PIP (picture in picture), which lets you watch two pictures at once.  Push the PIP remote or go into the settings to turn the box off.
1helpful
Tiny picture
try hitting the PIP button on the remote, sounds like it is in PIP mode, and the vizios have many configurations of PIP
5helpful
Visio LCD TV - Partial Picture blacked.
Hello! I have a 32" Vizio LCD...within 30 minutes of the tv being turned on, black lines start running through the bottom half of the screen and eventually blacking out the bottom half of the tv screen. It also doesn't have anything to do with the ratio as I have tried that. HELP!
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
