Question about TP-LINK External ADSL2+ DSL Router TD-8810
How to setting router? - TP-LINK External ADSL2+ DSL Router TD-8810
Posted by joshfeeder on
Andik Fitriansyah
    Sergeant:
  • 146 Answers
First open web administrator by open your browser, type these address 192.168.1.1
username admin
password admin
Posted on Mar 08, 2011
Testimonial: "thanks. and i forgot to ask how to setting connection to ISP.... silly me"
I need to rest my router
YOU CAN RESET THE ROUTER TO FACTORY SETTINGS
You may reset router to factory setting from the reset button on the back side of the router. Use a paper pin to press the button for few seconds, the lights on the front would blink and the router would restart with factory setting. Please not that ALL SETTING WOULD BE LOST...AND YOU WOULD HAVE TO MAKE CONFIGURATIONS AND SETTING ALL OVER AGAIN
HOPE IT HELPS...Let me know if you need any further assistance
CreativeTECH
Nov 16, 2010 | NetGear Computers & Internet
Security settings--numbers
Your wireless network must be secured
You will need to check the wireless settings of the router.
Is there any computer online using the router.
check the IP address on that computer.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
Click Here for more information about the routers and network
Jun 03, 2010 | NetGear WGR614 Wireless Router
Cannot get on xbox live lost cd
is there any computer connected to the router ?
Router set up page is the page where you can check all the wireless settings of the router.you will need to reduce the MTU settings on the router to 1365.
You will also need to trigger some ports on the router.
For this you will need to open the router set up page.
Router set up page is the page where you can change the settings of the router
Click Here to know more about router and network
Jan 30, 2010 | Belkin (F5D7230-4) Router (587009)
Connecting my xbox to lynksys wrt54g router
Jan 30, 2010 | Linksys Wireless-G WRT54G Router
Nintendo's support page doesn't list Dell routers
router
that computer.
once you get the wireless settings of the router, you can try to connect to the wireless network.
Click here for step by step instructions
Jan 23, 2010 | Dell Wireless 2350 Router
Router settings
Router set up.
Router is not working.
NO CD.
How to set up router.
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Dec 11, 2009 | D-Link DIR-615 Wireless Router
How to set up the router? can only connect to the Internet when the laptop is connected directly through the router
The wireless router needs its wireless settings configured and also the wireless card in all the laptops needs to be configured with the router’s wireless settings so the laptops can communicate with the wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Nov 15, 2009 | D-Link DIR-615 Wireless Router
Modify settings on router
To change the settings of the router you will need to access the router set up interface.
When you change the settings on the router make sure that your computer will be connected to the router with the cable.
I hope the following link may guide to open the router set up.
Click Here for step by step solution
Nov 01, 2009 | Linksys WRT160N Wireless Router
Router password trouble
you may try resetting the router settings by pressing the reset button of the router at the back of the router, there is a hole at the back of the router, you need to have a paper clip or any ball point pen to press the reset button of the router. The catch in here is all the settings of the router will set back to factory default so if you will be resetting the router allo the settings you have configured and set on the router will be set back to the default settings so you might alos loose your Internet connection.
Default settings on the router's log in - nothing for username and password is admin. Username as in blank and don't put anything into it.
Jul 07, 2009 | Computers & Internet
TP-LINK External ADSL2+ DSL Router TD-8810 Logo
139 people viewed this question
Top TP-LINK Computers & Internet Experts
Zaid Anarwala
Zaid Anarwala
Lawrence Oravetz
Vernon Taylor
Are you a TP-LINK Computer and Internet Expert? Answer questions, earn points and help others
