SOURCE: Shuffle won?t synchronise with iTunes V.7 using Mac OS X v10.3.9
Upgrade to iTunes 8 - ver. 7 was extremely buggy for both Windows and Mac
SOURCE: Ipod shuffle not recognized
Usually the solid orange light means it is charging but no connected to itunes. Let it charge for a while then try the reset. If none of this works, take the ipod back to the retailer where you bought it and exchange it for a different one. If the second ipod does the same thing, you most likely have a USB issue. For that you will either need to update the drivers or other software. Possibly even need a new USB card all together. If possible try a known working ipod with your computer. If that ipod loads fine, it is the ipod shuffle for sure.
SOURCE: iPOd Shuffle 2nd Generation incompatibilities with iTunes
Couple of things,
1. You need to choose a playlist to sync music with ur iPod. Make sure you selected a playlist with some songs in it.
2. Disconnect ur iPod, restart the PC and then try to sync
3. Try an upload from a different computer.
If none of these work, then you need to restore ur iPod using iTunes, check out apple's site to do it and then try it.
SOURCE: i purchased a used ipod shuffle. i just bought a
Update the drivers for computer to recognize the player. You can go to the manufacture's website, download the drivers. Once downloaded, double-click the file that was just downloaded, then it will install the files into your computer. Then once installed, restart computer and then you should be good to go.
