Question about Sony Ericsson Walkman® W995 Cell Phone
I got Sony Erecsson W995 5 months, following Buttons Yes, No , scroll down, 2 and 3 stopped working. rest of the buttons are working perfectly
Posted by bonnie846 on
Jeremy Moore
  • 1,940 Answers
Sounds to me like your keypad is faulty. You will need to contact your Cell Phone provider for repair, or contact Sony for repair or replacement of your phone. I have been unable to find the part you need to replace online, but I am sure Sony will have it available.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Posted on Mar 08, 2011
Samsung gt s 7262 how to restore
  1. Remove and insert the battery.
  2. Press and hold together Volume Up + Home + Power button.
  3. When you see the logo Samsung release Power button.
  4. When you see little man Android release the rest of buttons.
  5. Then if you see recovery menu select option "Wipe Data/Factory Reset" with Volume buttons and confirm with Power button.
  6. Scroll down to "Yes -- delete all user data" and confirm with Power button.
  7. If the operation is completed select "Reboot System".
  8. enjoy
May 23, 2015 | Samsung Cell Phones
I have a trio stealth g2 and have been locked out how do you rest to factory settings
1. While the tablet is off, press the Volume Up and the Power buttons at the same time. Let go when the Android recovery screen appears
2. Press the Power button to bring up the recovery menu.
3. Using the Volume Down button, highlight "wipe data/factory reset"
4. Press both volume buttons at the same to select the option.
5. Scroll to and select "Yes - delete all user data"
6. Once the wipe is completed, select "Reboot system now"
Oct 25, 2013 | Tablets & eReaders
Samsung gt i5503 touchscreen not responsive
Step by Step Follow The Tricks
hard rest without touching the screen
1. REMOVE BATTERY & PUT IT BACK
2. HOLD VOLUME UP BUTTON & MIDDLE BUTTON (HOME BUTTON)
3. WHILE HOLDING THIS TWO BUTTON PRESS POWER BUTTON AND REALEASE(PRESS POWER BUTTON ONLY ONCE)
4.IT WILL POP UP WITH HARD RESET MENU
5. SCROLL DOWN TO FACTORY RESET WITH VOLUME DOWN BUTTON THEN PRESS CENTER BUTTON OR HOME BUTTON
6. THEN PRESS VOLUME DOWN BUTTON TO SELECT YES FACTORY SETTINGS THEN PRESS CENTER BUTTON
7. SELECT REBOOT DEVICE AND PRESS CENTER BUTTON
TESTED 1000% WORKING
May 18, 2012 | Cell Phones
With the Tomb Raider Angel of Darkness (here on out in any more posts refered to as 'TRAoD') the skip level cheat is: "Pause the game and press and hold L2 + R2 + Down + Triangle. Then press Circle,...
First, yes that is the "Skip Level" cheat. It will also unlock a "Level Select" option on the main menu.
Secondly, you press L2 + R2 + Down + Triangle, THEN release, THEN quickly put in the rest of the buttons. You don't hold those first four buttons down all the time. You must do all this quickly and smoothly.
Hope this helps.
Apr 11, 2011 | Sony PlayStation 2 (PS2) Console
How do I remove the video banner on the wega kdf-42we655 screen
The info banner of your HDTV is turned on. To remove or turn it off, just simply follow these steps.
1. Press Menu (on remote commander)
2. Press UP or DOWN arrow button to highlight the SETUP icon and press ENTER
3. Use Down arrow button to scroll down through the Info Banner.
4.Press Enter to select this feature.
5.Use arrow buttons to scroll through options on or off .
6.Select off and press enter button to disable the info banner.
7.Press menu to exit.
Oct 25, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have the error C0F32 (Minolta - 210) on my display. I have to replace some parts ou just put some code?
Yes, you have to replace the parts which are necessary to be replace.If you do not want to replace the parts and also want to get rid of this problem then please perform these steps.....
1-Press utility button. 2-now press these buttons quickly stop, 0, 0 , stop, 0, 1. 3-You are now in service mode.here, scroll down and select ADJUST. 4-Now select ATDC gain. 5-Now increase the value shown on the display for example if the value is 145, increase the value to 165 or 170. To increase the value, press the C button to clear and now enter the new value by pressing the numeric keys on panel. After this press yes button and then press rest button.Re start the machine and start making copies..........
Aug 26, 2010 | Konica Minolta bizhub 180 All-In-One...
When turning on Camera in either mode, creates a continual roll. Like the vertical hold on older televisions will not stop. Sony was no help.
I had the same issue. I pressed and held various buttons and it apperently worked. This is exaclty what I did. Whether it is correct method or not, it resolved the vertical scrolling.
1- I had the camera siting in it cradle with the power cord connect to it. I pressed the tiny reset button
2- I pressed the easy mode and wide select buttons
3- I pressed and held the START/STOP button until it stopped scrolling. This seemed to reset everything and I had to reset the date and time which was no big deal.
Best of luck!!!!
Dec 29, 2009 | Sony Handycam DCR-SR62 Camcorder
Want to know can I set date and time
Yes. With the camera turned on, press the Menu button, and then scroll left or right until you are on the settings menu (hammer and wrench at the top). Scroll down until you are on the date/time setting option, and press the SET button. Use the left/right buttons to select month, day, year, hour, minute, and use the up/down buttons to change settings. Press SET to save, then press Menu to exit.
Apr 24, 2009 | Canon Cameras
Ps2 dual shock2 controller not working
Yes! your right, it's inside of the controller .what you can do is open the controller clean the board by using cotton buds with alcohol or cleaner you will notice accumulated dust preventing the buttons from touching the board you need to remove those.
Jan 25, 2009 | Sony PlayStation 2 (PS2) Console
My Player stopped working
press the rest set botton at the bottom of your walkman
May 23, 2008 | Sony Walkman NW-A808 MP3 Player
Sony Ericsson Walkman® W995 Cell Phone Logo
65 people viewed this question
Top Sony Ericsson Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Zaid Anarwala
Zaid Anarwala
Marvin
Marvin
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
