Question about Jacques Lemans Classic Automatic Chronograph 1216E Watch for Men
My watch stops working, the mechanism works on motion or kinetics. However, even with a bit of a shake it works for a bit then loses time and stops altogether
Posted by henry_abraha on
David Tolond
    President:
  • 2,501 Answers
It may require rather more than a bit of a shake! Some makers say that you have to swing it gently form side to side for 200-300 times to fully wind up the watch.
I bought one some years ago that didn't work well and I had it cleaned, after which it worked perfectly for years.
If giving your watch the shaking I described above it still does not work, try having it cleaned.
Automatic watches thrive on being used but should run for 2-3 days before stopping.
Posted on Mar 08, 2011
Do new James Michael pocket watches come with a battery?
Yes, if it is of the battery type
Movement Type
The movement, or inner workings, of a watch are what make up the main timekeeping mechanism. This mechanism measures the passage of time and displays the current time and other information including date, day and month. These movements can be entirely mechanical, entirely electronic or a combination of the two.
Mechanical movements, such as hand wound or automatic watches require winding in order to run. An automatic watch uses the force of gravity to constantly wind itself. Automatic watches have a greater consistency of power and therefore can be more accurate.
An electronic watch employs the use of a tiny quartz crystal that vibrates in the presence of electricity. This type of watch is powered by a battery and their time is regulated by the tiny quartz crystal. This is why most electronic watches are also called quartz watches. Solar powered watches convert energy from light into electricity which is then stored in a rechargeable battery. These watches do not need to have the battery replaced as long as they are regularly exposed to a fairly strong light source.
Kinetic powered watches use a combination of mechanical and electronic elements. Usually a weight rotates with the motion of the wearer?s arm which turns a generator to supply power. It is similar to an automatic watch except that electrical power is generated by the mechanical motion.
Men James Michael Pocket Watch
Jun 19, 2016 | Pocket Watches Watches
WHAT IS KINETIC ENERGY
kinetic energy is an expression of the fact that a moving object can do work on anything it hits, it quantifies the amount of work the object could do as a result of its motion.
Mar 19, 2015 | Watches
I have a Movado Series 800 Subsea. It stops running when it's not worn. If I shake it, it starts up agin. I know it's a quartz hence a battery. Is it kenetic? The manual does not say.
It is not kinetic, the watch should run whether it is worn or not. A kinetic watch requires motion in order to wind a mechanical movement. A quartz movement requires a battery and that is all. You might want to change the battery.
Feb 17, 2014 | Watches
10 year old Seiko Kinetic (model5M62-0B00) blue face. Last week stopped and after some shaking started again but seconds moved in 2 sec intervals for a few hours. Went OK for a week and again last night...
After 10 years it will be likely that the Kinetic capacitor will need upgrading. Your watch is designed to tick in two second intervals to tell you the power is very low. The power button will work again when it has some power to show. Yorkshire Watches www,yorkshirewatches.co.uk can do the upgrade for you if your in the UK. Give them a ring.
May 23, 2011 | Seiko Kinetic watch
Breitling Colt Kinetic Watch - not working
I read the instructions for a similar type of watch and while the battery will keep the watch "alive" for some months when not in use, eventually the battery dies.
Since it is a kinetic watch the instructions I read said that you should gently shake the watch about 500 times to recharge the battery!
If you give it a good shake and then wear it for a few days, it should recharge itself, although it may have forgotten the time and may need re-setting.
Mar 01, 2010 | Breitling Colt Oceane 504 Watch
Bulova Watch Millennia Motion 96B17 - stops - needs battery????
Dude, of course it stops during the night - it's a perpetual motion / kinetic watch. It doesn't have a conventional battery. When you move your arm (while wearing it), the natural motion of your arm will 'automagically' wind the watch. There's nothing wrong with it - these types of watches always have to be re-set in the morning if you don't wear it to bed (or you don't toss and turn in bed).
May 30, 2009 | Bulova Millennia World Time 98G66 Wrist...
Tag automatic watch = stopped working
Stop shaking it!
You could try wearing it and it should wind itself with your body motion or...
your could manually wind it (setting 1)
Jan 22, 2009 | Tag Heuer WAF2110.BA0806 Aquaracer...
Regarding automatic watch
Sorry for my first comment I thought your watch is battery operated this is not ,your watch is mechanical not electronic watch. Your watch is self winding is an automatic,even you do not use its ok,nothing happen to watch..
Batteries generally last years in a watch and a mechanical wind up watch will last forever as long as it's kept well. Now there is a third choice of Kinetic watches. These work by utilizing the motion of the wearer's arm. This motion is used to store energy in the rotation of a flywheel or a coiled spring, which then drives a micromotor that drives the watches mechanism.
Hope this may help;
Regards,
VOTIT
DON’T FORGET TO RATE;
Aug 10, 2008 | Tag Heuer WAF2110.BA0806 Aquaracer...
Seiko Kinetic that doesn't work
This watch does not have a battery, but has a capacitor which is rechargable. It is not taking a charge, and needs to be replaced. You should take it to a store with a watchmaker ON THE PREMISES. Or you could send it to: www.bscwatchrepair.com
Jun 27, 2007 | Seiko SKA192 Wrist Watch
Jacques Lemans Classic Automatic Chronograph 1216E Watch for Men Logo
506 people viewed this question
Top Jacques Lemans Watches Experts
Janelle Schoonover
Janelle Schoonover
Marvin
Marvin
Tom Chichester
Are you a Jacques Lemans Watch Expert? Answer questions, earn points and help others
