Question about Nokia 2626 Mobile Phone
2626 charging not support problem diagram - Nokia 2626 Mobile Phone
Posted by ramesh_sawan on
  • Nokia Master
  • 17,130 Answers
Recheck your phone with another charger which is amply available in the friends circle, once confirmed the charger can be replaced. There are cases in which the circuit functions improperly , sometimes the capacitor can be replaced to rectify the faulty.
other wise as these needs to be broken open the charger can be replaced.
If your charger test also give the same result, then the battery or the charging circuit in the phone is faulty.
Posted on Mar 08, 2011
Nokia 2626 charger not supported solution
my nokia2626is not charging when we conect charger it show charger not supported kindly help me
Feb 22, 2011 | Nokia 2626 Mobile Phone
Pa jumper pin no of nokia2626
Nokia 2626 Signal No Network repairing solution.Nokia 2626 Signal No Network Mobile Repair diagram pictures Service Tips and Tricks.Make Jumpers as shown in diagram or replace the shown components .
How to short Nokia 2626 PA.jumper Pa nokia 2626. here is a diagram that is showing how to jumper and short P.A of nokia 2626. it is used to check that mobile is getting signals or not. if signals are to low with jumper change the P.A
Jan 21, 2011 | Nokia 2626 Mobile Phone
Nokia 2626 charging not support
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Secend Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Aug 31, 2010 | Nokia 2626 Mobile Phone
Please help my nokia 2626 charger not support problem
First Option:
Secend Option:
Jul 13, 2010 | Nokia 2626 Mobile Phone
Sir plz hep me nokia 2626 charger not supported any solution
I advice you try use a similar charger to charge your phone, if the problem still persist, i mean if the similar charger did not charge the phone, it means the charging port of your phone is bad and will need to be replace, i advice you replace the charging port of your phone if no charger charges the phone, replacing the charging port will help and get your phone charging.
Take care.
Jul 06, 2010 | Nokia 2626 Mobile Phone
In nokiya mobile 2626 not charging batterey
haw to ripeair not carging iwant jumper
Apr 16, 2010 | Nokia 2626 Mobile Phone
My phone is getting switched off for every 2mins..its nokia 2626
problem should be with the battery or some internal software issue. charge your battery well.
Nov 11, 2009 | Nokia 2626 Mobile Phone
I forgot my phone Nokia 2626 security code...how to unlock?
I want Nokia 2626 Master Reset Code,,So pls Brother Kindly give the favour and solve my problam,,i forget my code
Aug 14, 2009 | Nokia 2626 Mobile Phone
Nokia 2626 Mobile Phone Logo
309 people viewed this question
Top Nokia Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Zaid Anarwala
Zaid Anarwala
