If you get issues like Faxes can be sent but not received, Faxes can be received but not sent error on your Printer then follow the given troubleshooting steps. Solution to Faxes can be sent but not received
·Initially, you have to check any of the telephone line services are enabled. There are,
1.Voice Mail
2.Call Waiting
3.Billing Tone
4.Privacy Block
5.Security Screen
6.Anonymous Call Rejection
7.Privacy Manager
·These may block your incoming faxes. So disable the above features.
·If you are using Automatic fax reception option on your fax recipient, then check whether the Automatic Answering feature is enabled or not, if it enables means Auto Answer green LED should be on.
·Check the Ring to Answer value.
·If the value set as answering machine that causes the issue on fax reception. Then change the value to Fax or FaxTel
·Now, you can receive the incoming faxes. Solution to Faxes can be received but not sent
·Check whether the dialed number is correct or not. Every one of the digits required to make a telephone call from a similar line must be dialed.
·On the off chance that the Speed Dial has been used for dialing or the fax has been sent from your PC, print the page to be faxed and dial the number physically on the HP Fax front board.
·Check whether the Tone Dialing is set on you HP Fax product.
·In the event that faxes are sent effectively from the HP Fax front board, but, it's fail when sent from the PC, test the communication between the HP Officejet 4650 printer and your PC by tapping the Status button in the HP Director application, or attempting to print some record.
·If the printing fails to send the fax, then check whether all cables (from system to HP Officejet 4650 Printer) are connected properly, if it's not then connect it properly.
·Now restart it. On the off chance that communication still can't be set up, Call Printer customer service team via Toll-Free: +1-800-836-3987 to resolve your HP Officejet 4650 fax issues.
Printing irregularites on sent faxes are due to spots or a dirty scanner.
Spaces on received faxes are due to a dirty drum, corona wire, or a failing or improperly installed toner cartridge. A new cartridge should be gently shaken back and forth sideways prior to installation.
All you need to do is push the option button, keep pushing option button to scroll through settings. you will find the print all function for faxes. Hope this helps. Good luck.
You can not send faxes thru the internet unless you use a service such as E-Fax. Faxes usually are sent via phone lines only. If you are asking anything else then you have to be more precise in your question as it is not exactly clear as to what you are asking!
Reason of this Problem:
Actually it happens due to mem full in Sent Items with Pending Status.
Solution: --------------
Just delete one message from Sent Items.
Better if you delete all messages from your Sent Items, as you will face again this problem if again Sent Items fulls with messages having status Pending.
Try with using the fax's cleaning tools. They can be reached by going to:
Control Panel -> Printers and other Hardware -> Printers And Faxes
When there, right click on your fax and click properties. Then go to the tab Maintenance and use the cleanings tools provided there.
