Cars & Trucks Logo
Posted on Mar 08, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1996 Mazda Protege with 100,000 miles. Should the serpitine belt be changed? What is approximate cost?
Anonymous
Level 3:
  • Mazda Master 1,940 Answers
  • Posted on Mar 08, 2011
Anonymous
Mazda Master
Level 3:
Answers
1940
Questions
0
Helped
954176
Points
5951
A recommended replacement interval for serpentine belts would be every four or five years, or 50,000 miles. I usually just check for Cracks in the Ribs of the belt. If I see cracks, I replace the belt. If you do this job yourself, the belt shouldn't cost much more than $20.00. I am not sure how much the person you get to change the belt is going to charge you, but I personally charge $75.00/hour for services. It would usually take me less than an hour to change a serpentine belt or belts.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Anonymous
Level 2:
  • Expert 115 Answers
Anonymous
Expert
Level 2:
Answers
115
Questions
0
Helped
40141
Points
362
The factory said it should be changed every 90,000 - 100,000 miles. Cost for the belt is about $40.
A
Anonymous
Drive belts are replaced every 5 years
Your thinking of timing belts 80,000 miles
On a Mazda protege 5 do I have to change the timing belt to change a bad water pump
Usually it is a good idea to replace any of the belts if you have to take them off to do repairs. Belts aren't usually expensive to buy. A timing belt is a major service item on higher mileage engines, (60,000 to 100,000 miles), so replacing it is always worth doing.
2answers
When should a timing belt be change on a mazda cx
Contact your local Mazda dealer and ask them. Manufacturers all have different intervals for specific type of services and maintenance.
Some vehicles have a belt and others have a chain. In belts, most commonly are changed within 80,000 to 100,000 miles. With chains, as long as you maintain your oil changes up to date, no need to replace. But consider that hard driving affects the overall performance of this component.
2helpful
2answers
At what milage do we need to replace timing belt?
it is best and reccomended to change timing belt every 60 to 80 thousand miles, or sooner if bad. have a good day ! some belts will last longer but it is best to change it at about 60 to 80.
1helpful
At what mileage does the timing belt require changing, as per the maintence guide? This is for a 2002 maxda protege 3, auto trans, 5-dr. hatchback.
if your car has more than 100,000 miles then it's advised that you change the timing belt on your car. Good luck
Mazda 2002 protege, when does the timing belt need to be replaced
If you're the original owner, 100,000 miles is recommended. If you bought it used, 75,000 because you don't know what it's been through . . .
At what mileage should I replace timing belt on protege 3
80,000 to 100,000 miles if you drive it "normally".
20,000 miles sooner if you drive it hard.
-Jim
I have 97000 miles on my 96 Mazda Protege LX. How
The belt shold be checked at 60,000 don't let it go past 100,000 Without replacing you you will be buying a new engine.
Timing Belt replacement- two recomendations by mazda manual
they are good for well over 100k. If your engine is freewheeling (that is - if belt does break, no valve will hit the psiton), I would just keep driving it until it breaks or never does.
I am driving my 93 Villager until it breaks. over 150k right now, freewheeling engine.
As for cost, about $400 is my guess.
Ask your dealer service dept if it's freewheeling. check your owner manual too.
1helpful
Replacing 2 belts on a 2000 Mazda Protege
I recommend that you go to any Auto Parts store and by a repair user manual for your 2000 Mazda Protege.  They have pictures and arrows and stuff that you will need to do the whole job.  The non-Mazda version will cost approximately $15.00.
Because of the tensioner that may come off when while you are doing these belt changes, it is too complicated to talk you through this.
But with the manual, I am confident you can change them.
1helpful
Timing belt
usually around 100,000 miles depending on how the car has been driven. Or just wait till it breaks. I've seen over 200,000 miles on the original belt. If it were mine, I'd do it every 75,000 to 125,000 miles. I don't like being stuck in the middle of nowhere :)
Top Mazda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Mazda Expert? Answer questions, earn points and help others
