If the E1 error occurs after the belt starts to move for several seconds, the error code means that the system is not picking up the speed of the motor. This pickup comes from a magnet mounted on the front roller pulley and a speed sensor, or a problem with the magnet.Feb 29, 2016
Loose or broken parts under the motor hood of your treadmill can cause the machine to not start. If the console lights up, but the treadmill won't start, the motor controller could be damaged. Loose wires under the motor hood or in the console can cause your treadmill not to start.
https://www.youtube.com/watch?v=a2FCo3JTO00
E02 error code: control board or motor issue. Test the motor first to check if the motor can runing normally. If motor is normal, replace the control board. E03 error code: 1,Turn on the treadmill , motor running a few seconds then stop and console board shows E03, probably the Speed sensor issue.
https://anytreadmillparts.com/pages/treadmill-error-code-troubleshooting
LUBE THE deck belt,+rollers bearing front and back. test the drive belt motor, and replace the belt if necessary. However if the problem persist, TIME to replace the deck belt God bless you
Sounds like you could possibly have a bad drive motor or something is wedged into the walk belt somewhere keeping it from turning. Check this out. One more question. How long does the walk belt turn for, seconds, before it stops. Is it like 3 to 5 seconds or less than that.
