If you saved the pictures to your cameras built in memory, chances are that you cant transfer the pictures from the camera straight to the memory card. You have to FIRST transfer them to your computer and THAN from your computer to your memory card.
SOURCE: Transferring images on camera memery onto memory card.
I had the same problem, and I found after much playing and mostly accidental findings that I could do this by following these steps
1. Put an SD card in the camera. Will not work otherwise
2. Go into playback mode, where you view the pictures, button looks like an blue arrow pointing to the right
3. Press the round 4 way controller downwards, and a menu (that I have never seen before!) appears
4. Choose the 4th icon along on the top line and that will give you options to transfer from memory card to camera and the other way around.
SOURCE: How do I transfer pictures onto the memory card?
Go to the camera's "setup menu" and scroll down to the last option, "move images to card" That should put the images onto the memory card.
SOURCE: Saving pictures
The camera has a very limited storage space on itself. It probably isnt saving the pictures on the card because the card is write protected (probably on accident)
just pull out the card and on it is a tiny little switch. just push that into the next position and it is no longer write protected. the write protection is there to prevent you from losing your photos, to put more photos on it you will have to deactive the protection with that switch, its usually white colored
SOURCE: move pictures saved in camera to card
Best thing to do is upload them to your computer. The camera does not allow you to move from camera memory to card.
SOURCE: pictures taken with camera and no memory card inside how to
There is a copy option on the playback menu.
This copies to and from the memory.
