If the set is responding to the remote or set-top buttons, this means only that the always-on low voltage supply for the remote section is working and that the main power supply has probably died. You might try pulling the AC plug overnight to see if there is simply a 'lockup' of an IC causing the non-response. Our modern sets are very complex and it isn't uncommon for them to have a glitch while operating.
I left it unplugged (from the wall) overnight last night hoping that would help. Will it make a different if I unplug the whole cord that goes into the tv? Thanks!
Unplugging from the wall takes away the source of power without the need to disconnect from both ends. If the overnight 'rest' didn't allow the circuits to reset, I'm afraid the power supply has failed. This type of failure is often caused by the use of cheap electrolytic capacitors in the power supply and is pretty common. If you want to try to fix this yourself, reply back to this thread and I will post a fairly long set of instructions on how to proceed.
Before opening the back of your set, pull the plug and allow to sit; preferably overnight.
There are nasty voltages inside that you want to avoid.
The main power supply is often on a separate board, will have larger-than-average parts on it, with cylindrical parts (mostly capacitors) and some larger squarish parts (chokes and transformers) and most likely a 'heat sink,' a finned aluminum structure with parts attached to it.
Look for a tag with a part number on it and have this available when you start looking for service or new board.
I suggest you contact the service center for your area and inquire about the cost of board repair or replacement. If the latter, keep the failed board since there are small shops (I was one before retirement) with the skills to repair these at a more reasonable cost.
These assemblies are nearly always only plugged into the rest of the set with clearly dissimilar plugs so incorrect connections are somewhat prevented.
If you are unsure of yourself, take several pictures of this area before disconnecting anything that you can then refer to if uncertain.
Remember, many assemblers of most of these just recently came in from small farming villages in Asia so assembly is kept simple.
Good luck-
Thank you for the information. I will let you know what happens. Thanks again for all your help!
Pictures in my albums and my guides may help you out also.
Basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Yes I would love to try and fix this myself. I appreciate your help. Thanks!
