Test all power and data leads that attach to your hard drive IDE SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure dust free connections and are not faulty
computers need power and data to travel through every working device and to continue its cycle and to have an end so any faulty leads will end up with a computer error
Click start control panel administration tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
You might need to upgrade your graphics card drivers
you might have to remove your graphics card to make sure the socket is clean
restart your computer the reinstall it this should activate found new hardware wizard
if your computer came with a mother board disk the drivers could be on it
click start control panel display desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
windows 7
Open Personalization by clicking the Start button, clicking Control Panel, clicking Appearance and Personalization, and then clicking Personalization.
Click Window Color and Appearance.
Under Window Color and Appearance, click the color you want, and then click OK.
Note
If you see the Appearance Settings dialog box instead of the Window Color and Appearance
window, the theme might not be set to Windows Vista, the color scheme might not be set to Windows Aero, or the computer might not meet the minimum hardware requirements for running Windows Aero. For more information, see Troubleshoot problems with Windows Aero.
hope this helps
