You can see the PDF manual here:
http://www.viewsonic.com.pe/pdf/userguides/e771-1_user_guide.pdf
I hope this helps,
Magoo
He is a link to the main support page for this monitor.. The maunal is located on the right side, but instead of maunal it is called user guide.
http://www.viewsonic.com.pe/support/desktopdisplays/crtmonitors/e2series/e771/
SOURCE: My viewsonic monitor is not working
Considering the price of monitors versus the cost of repair. It would cost less to replace the monitor.
SOURCE: e7oFb viewsonic crt monitor a
I don't know this particular model, but there are a few things you can check should you wish to retain the monitor.
1) If the unit has the older rotating controls, try spraying them with electronics switch cleaner (with lubricant). Work them back and forth a few times with the power off.
2) If the controls are the tact switch type, with the power off, press all of them and you should feel them engage. If not, replace the switches. They should be available generically for about 25-50 cents each.
Dan
