Question about Hitachi Cpx2510 Projector Cpx2510 Xga Projector Lamp
The image is very dim, even on maximum brightness. We are considering replacing the bulb, but bulbs for this projector are very expensive and we suspect that since there is some image, the bulb is not the problem. More likely a power supply or circuit board problem. Can dimness be caused by a bad bulb?
Posted by shankwiler on
Anonymous
    New Friend:
  • 24 Answers
Yes, as bulbs age they will begin losing brightness. Most projectors have a bulb life hour clock, that measures the number of hours a bulb has been used. Usually you can pull that up within the menu of the projector. Also that particular model has what is called "Eco-Mode" and when engaged dims the bulb by 25% to cut down on power consumption.
Typical life for a lamp in that projector is:
3000 hours on Normal mode
6000 hours on Eco mode
You can expect a brightness loss of 50% when you are approaching end of a lamps life.
Posted on Mar 07, 2011
I have a Kodak Ektagraphic with no model listed on it at all. How can I find a replacement bulb, all I can find look wrong.
Supplied with 82V, 300W EXR lamp Projection Lamps Quartz-halogen 82 V projection lamps- Here is service manual link http://resources.kodak.com/support/pdf/en/manuals/slideProj/manual/ektagraphic_sm.pdf Several different Models all say EXR 300W As CORRECT Bulb : EXR, 300 W (35-hour lamp life at full lamp/medium-brightness) Sampling of other lamps: EXY (200 hours/less brightness) EXW (15 hours/maximum brightness) FHS (70 hours/medium brightness) Use combinations of lamp brightness, plus half- and full-lamp settings to approximate image brightness in multi-projector presentations. Lamp Tips • Projector operation on line voltages above 125 volts greatly reduces the lamp life. • Unplug the projector before changing the lamp. • Allow for unrestricted flow of air to the exhaust vent to prolong lamp life. • Gently wipe off any fingerprints with a soft cloth moistened with rubbing alcohol.
If you need further help, reach me via phone at https://www.6ya.com/expert/richard_b70d968cd1a1d293
Jun 27, 2016 | Kodak ATS Ektagraphic Slide Projector
Need to adjust the brightness. The projection is too dim to see clearly in a classroom.
Appears bulb is burning out ?
If this is a replacement bulb, is it a proper replacement ?
Not all bulbs are dim-able.
May 12, 2014 | NEC NP100 Projector
Time to change bulb??
Check the lamp. It might be faulty. [low light intensity]
May 11, 2012 | Vivitek D732MX DLP Projector, 3200 ANSI...
Picture way too dark to watch comfortably. Have already adjust all settings to maximize brightness. Bulb was replaced late last year and says 1,000 hours have been used but projector has not prompted me...
Unfortunately dim image is normally due to a defective lamp assembly. I'd recommend removing the lamp and inspecting its condition. You'll notice black corrosion build up or a bubble is starting to form around the filament of the bulb if it is what's causing the dim image.
Aug 06, 2011 | Mitsubishi HC1600 Projector
My Eiki lc-xb33 is projecting the image from my computer very dimly. Although the image is in focus, it is very difficult to see the image at all because it is so dim. Even the blue start up screen is...
You need to remove the cover and check where the lamp light is being attenuated in the optical path from the lamp to the front lens. I would try using a 12volt 50W halogen lamp in place of the real lamp and shine it into the optics system, and see where the brightness starts to go bad.
May 11, 2011 | Eiki LC-XE10 Projector Multimedia...
Projector works but image is very dim
Hello.
Here are 2 links for your Epson Powerlite 7300 projector:
User manual:
http://files.support.epson.com/pdf/pl53__/pl53__u1.pdf
User Replaceable parts list:
http://files.support.epson.com/pdf/pl53__/pl53__rp.pdf
And ... yes .. the replacement bulb for most projectors are very expensive.
Hope this helps.
Feb 23, 2010 | Epson PowerLite 7300 Multimedia Projector
Image is dim. How do I adjust brightness
You can adjust the brightness through the user menu, under the picture option. You might want to look at your bulb. It might be time to replace the lamp.
Sep 19, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Proector image is dim
I have changed the bulb on my LG projector recently. I found the rotating colour wheel to be full of dust. Upon opening the cavity where the light is redirected and reflected onto the imager, I saw all mirrors also had a layer of dust. I don't think it was so dirty that it affected the brightness of the image, but I cleaned it anyway using an earbud. I cleaned both sides of the color wheel as well. You need to be careful in working with the optics of the projector!
Sep 05, 2008 | InFocus X1 Multimedia Projector
Brightness Varying during operation
Inside all projectors is a lamp ballast that runs the lamp. It could be in the early process of failing.
This website will explain the whole ballast thing clearly. It is important that if your ballast is failing, then you get it replaced or you maybe infor another very expensive light bulb very soon.
Hope that makes your issue somewhat clearer (pardon the punn)
Apr 14, 2008 | Hitachi CP-X960 Multimedia Projector
Dim Image
Check you manual for a dual brightness control that may be activated or even stuck at low level. The manufacturers web site may have a technical help team to consult - have you tried?
Jul 16, 2007 | ASK Proxima DP6860 Plus Multimedia...
Hitachi Cpx2510 Projector  Cpx2510 Xga Projector Lamp Logo
Top Hitachi Office Equipment & Supplies Experts
Richard C Cohen
Richard C Cohen
ray gallant
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
