Question about Sony Playstation 3 (PS3) Console
Hi. My PS3 suddenly started turning off randomly in the middle of play (grrrrrrr) but I know its not overheating since the red light didn't flash and there was beeping. It just died. No joke. Does anyone know whats wrong with it?
Posted by magiclizzie on
Anonymous
    New Friend:
  • 9 Answers
There could be an issue with the power cord or the power outlet.
Try to get a replacement cord and plug the PS3 into another outlet. Turn on the PS3, and let it sit on the menu screen for a while. If it does not shut down it means that it was a power issue.
Posted on Mar 07, 2011
Testimonial: "Thankyou! That sounds better than sony's idea of re-soldering the wire..I don't even know what that means..but this is helpful. Thanks :)"
Game stopped playing and red light flashed without me making it.
Hello.
This flashing red light is due to your PS3 overheating. Let it cool for approximately 6 hours before turning it on.
If this happens constantly, then you need to make sure that the PS3 is not in an enclosed space (e.g. cupboards). The vents at the back and right sides of the PS3 must be 6 inches away from walls.
Hope this helps. If it doesn't work, let us know.
Jul 06, 2011 | Sony Playstation 3 (PS3) Console
My playstation will turn off by itself at random times after working fine. Its the original Ps3, not slim, and it gets played quite a bit. The problem is I'll be playing and it suddenly shuts off and has...
Your PS3 had hardware errors and need some maintenance. Do you know, send back to game shop is too expensive and waste your time. Learn the correct repair skills and fix it by yourself is the ultimate method. Here is the repair guide for you to learn :
DIY PS3 Repair Guide
Not only such overheat problem, you can repair other red and yellow light related issues as well.After you purchased the product, you will be guided to the step-by-step videos and ebooks for you to work with.
Jul 20, 2010 | Sony Playstation 3 (PS3) Console
Ps3 shutoff
your system is overheating, try to clean out the exhaust vents unsing a vacume with a brush head. Dont use canned air, this may work for a while but ultimatly all you are doing is pushing the dust further inside the unit. Also you can buy after market intercoolers for the PS3, Nyco makes a nice one!
Sep 27, 2009 | Sony Playstation 3 (PS3) Console
My ps3 suddenely turned itself off mid-game. turned it back onto standby mode, then when i turned it on the light went green as normal then suddenely red light came on with the green, three rapid beeps...
try this:
it works for slimline PS2. might work for PS3.
1) turn off PS3
2) unplug PS3 and wait a minute or two before plugging back in.
3) turn on PS3
hope this helps.
it could also be overheating.
Aug 19, 2009 | Sony Playstation 3 (PS3) Console
Ps3 turns off beeps twice but there is no yellow light only red!
The yellow light is also know as the yellow light of death casued by a hardware failure. It can be casued ny over heating a bluray drive failure, a hard drive failure or even a powersupply failure. You know you have it when you power up the yellow light flashes then you hear some beeps then the red llight flashes. I would suggest returning it if you have that option or getting it fixed somewhere else as a last option.
Jul 16, 2009 | Sony PlayStation® 3 (60 GB) Console
Ps3 wrecked
it has a bug if it is a 40 or 60gb they are the ones that have it.
Jul 08, 2009 | Sony Playstation 3 (PS3) Console
HELLO. I was playing on my ps3 When suddenly it just turned it's self off in the middle of playing tekken 5 DR oline. Now when i turn my ps3 3 on it just's beep's and turn's tisefe off.....HELP ME PLEASE....
Your PS3 probably overheated during game play.
No it's stuck in the "off" position.
There's isn't much you can do besides trying to reset the video.
While the PS3 is off (red led)
Hold down the power until you hear the second beep, quickly release.
Hopefully you're one of the lucky ones.
If not you need to contact Sony @ 1-800-345-SONY
for repair.
It's more than likely a motherboard issue.
Best of luck!
Jun 15, 2009 | Sony Playstation 3 (PS3) Console
Playing my ps3 and suddenly it turned off and wont turn back on.
Hi. this is a basic power supply issue. it has failed. you will need to replace the internal power board(supply). this will fix your issues.
Jun 04, 2009 | Sony Playstation 3 (PS3) Console
PS3 wont work
How long were you playing it? if you were playing for a couple of hours, then it could of just overheated, in which case the ps3 will shut itself off suddenly to keep from damaging something. It should work after about half an hour, adequate time for it to cool down, if not, then you might of damaged something.
Nov 21, 2008 | Sony Playstation 3 (PS3) Console
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
This may be caused by poor ventilation or the vents may be blocked.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
Dec 02, 2017 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
87 people viewed this question
Top Sony Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Marvin
Marvin
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
