Question about KitchenAid KFP740 Food Processor
Most likely it will be to do with the bowl or the lid. The safety mechanisms in both parts are likely culprits, they operate a micro switch just above the switch panel and hidden by the base of the bowl. Have just the bare motor plugged in and turned on with the run button depressed. Now with something plastic depress that small black button, the motor will likely start running. That proves motor is fine and you need to figure out which of the bowl or lid is the faulty part. The pusher needs to be in the lid tube before the motor will run in case you have forgotten.
Posted on May 02, 2017
SOURCE: My food processer does not work
I had the exact same problem. The red light came on when I hit the "On" button, but nothing happened. Then I noticed that when the lid is locked into place, a small pin in the handle goes into a small hole in the base. I took a wooden chopstick and poked it in this hole in the base, and the unit started running. I put the bowl and lid back on the unit and locked them into place, and this time the unit ran just fine. Yeah! I will remember this the next time my unit won't run even though I know that I've properly locked down the bowl and lid. Good luck!
Posted on Dec 05, 2008
SOURCE: Kitchenaid Food Processor - Center Stem Support doesn't turn
Grease, it needs grease to lube it.
Posted on May 16, 2009
SOURCE: Need to clean inside of handle on KitchenAid food processor
The plastic for the work bowl / handle is molded and one piece and cannot be disassembled. My best recommendation is to call Kitchenaid customer service to see what recommendations they have. Within one year warranty, they may replace the work bowl at no cost.
Their toll-free number is: 1-800-541-6390.
Posted on Jul 07, 2009
SOURCE: I have a kitchen aid food processor, it is on, but motor doess no
This sounds like an issue relating with the assembly of the machine. The motor is definitely getting power if the indicator is lit. However, Kitchenaid food processors are designed (as a safety feature) to remain unengaged if the unit is not assembled in such a way. Here is the proper assembly:
Please disassemble the unit. This means: removing the blade, removing the work bowl, the work bowl cover, and unplugging the unit.
Starting with the work bowl: place the handle at the 9 o'clock position, which is out to the left. Rotate downward to the 6 o'clock position until it locks in, centered over the button panel.
Repeat the process with the work bowl lid.
Depending on which food processor you have, you may need the feed tube pusher depressed at least half way down the feed tube.
Plug in the unit. The blade does not have be installed for unit it to work at this point, assuming everything is assembled properly and the motor is functioning. The motor should now be working.
SOURCE: my kitchenaid processor is not working
The Kitchenaid food processors have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. I am thinking this is an issue of assembly because the light is on, so the unit is definitely getting power.
Proper assembly is below:
If it isn't all ready, please disassemble the entire unit. This means removing the blade and/or disc, blade, removing work bowl, work bowl lid, and blade.
Start by placing the work bowl onto the motor base. The work bowl handle should be facing at 9 o'clock, which is out to your left. Rotate the handle downward until it locks in at the 6 o'clock position, which will lock over the center of the button panel.
Repeat the process with the work bowl lid. The blade does not need to be present for the motor to engage, if this is an assembly issue.
Posted on Aug 08, 2009
Mar 31, 2014 | KitchenAid KFP350 Little Ultra Power 5...
Sep 29, 2013 | KitchenAid KFP300 Little Classic 5 Cups...
Aug 22, 2013 | KitchenAid KFP350 Little Ultra Power 5...
Jan 19, 2013 | KitchenAid KFP600 Ultra Power 11 Cups Food...
Dec 23, 2012 | KitchenAid KFP7500B 12 Cups Food Processor
Nov 28, 2012 | KitchenAid KFP350 Little Ultra Power 5...
Apr 28, 2012 | KitchenAid KFP720 7 Cups Food Processor
Jul 29, 2009 | KitchenAid KFP715 7 Cups Food Processor
Jan 24, 2009 | KitchenAid KFP750 Food Processor
Feb 07, 2008 | KitchenAid KFC3100 Chef's Chopper Food...
560 people viewed this question
