Ir3300 error code E602-0003
Ir3300 e000602 0003 error solution
Check The Disk
And Reset All Data.
Or replace A HDD
Best of Luck
We have facing problem OF error is E000602-0003. Plz give us suggestion
Canon IR3300 Hard Disk Error e602 - 003 how to instol software
Steps To Fix Canon Hard Disk Error Code E602:-
Step 1: - Verify Hard Disk Cable
You should check the connection of the Hard Disk cable, maybe the wiring connection and the cable between the connector is not properly connected.
Step 2: - Check the Main Controller PCB
Turn OFF the main power of the machine and then verify that the main power indicator on the control panel is not lit properly. If the problem is not resolved, then you should try to replace the main controller PCB.
Step 3: - Verify HDD
You should check once again your Removable HDD Kit. Maybe a problem is occurring there.
Step 4: - Reinstalling the System Software
canon hard disk error code e602
It works... www.tonertree.com
what you need to do is just resetting your machine.
1. Press * 28 * on your machine in a quick move.
2. Select copier
3. Select Err.
4. Select Clear then press O.K
5. Turn your machine off for 1 minute and turn it on again.
The error code will not be there anatmoreand your machine will be functioning well.
