Bose SoundDock Portable Digital Music System (SOUNDDKPORTW) Docking Station Logo
Posted on Mar 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a BOSE soundock portable and I have to replace my connector at the end of the power supply.What is the size of the connector.
Anonymous
Level 2:
New Friend:
  • Expert 47 Answers
  • Posted on Mar 07, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
47
Questions
0
Helped
12720
Points
152
Bose uses a proprietary connector for their power supply. Your best bet would be to purchase one, for example at this site: http://www.frontrowelectronics.com/bose-power-supply-sounddock-series-1-white.aspx?utm_source=googleBase&utm_medium=referal&utm_campaign=Bose
The four pin connector is not standard and cannot be found in stores such as Radio Shack, etc.
1helpful
Bose soundock 10
You want to plug the SoundDock into a 220 receptacle, is that correct, and the Soundock works off of 120v., correct. I tried to find the specs for the Bose SoundDock, i.e. its wattage rating but it seems that Bose does not publish these specs. At any rate a 220v to 120 v converter should work
The 300 watt converter listed above should work fine. Wahtever converter you use, make sure it operates at 60/50 hz.
My bose sounddock portable system suddenly stopped working so I thought it needed charging, when I plugged it back in to the mains it wont charge and no light comes on the system at all it's totally...
Guys - she has the protable!! Hi Fiona, the best bet is to visit www.invebo.com and check the SounDock Portable diagnostic video. (Repair video is there too) Remove the battery and plug the power in., If you get a beep-beep sound then the unit has power and is booting up so you need a docking connector replacement kit. . If there is no beep beep then it is the power supply or the main unit. (Try a different power supply) . If it works normally then it is the battery - get a new battery. Hope that helps.
I have a Bose Portable Soundock and recently it hasnt been playing or chrging on the dock, but it does play when i have my phone plugged in the back, so the speakers do work. I read online to replace a...
Go and have a look at the website http://www.invebo.com They sell replacement Docking Boards which is almost certainly what you need. They also have some guidance on how to select the right version based upon your SoundDock model and whether it beeps whn you plkug in the Power Supply
Connector on the back of my Bose sounddock came out.....now what?
Take the sound processor board out and sens it to the guys at www.invebo.com they change the connector for 16 Euros. It takes a couple of days. They also sell the USB charge upgrade to enable you dock to charge the IPHONE on the Soundock original.
Bose sounddock not giving any sound. Ipod working fine through earplugs. Unhooked soundock for travel, now no sound. Tried all the resets, etc. Also, new battery in remote and it doesn't respond either????
You probably have a broken docking connector or bad power supply. Contact www.invebo.com to get a replacement board. It takes minutes to fit. They also sell the USB charge upgrade to enable you dock to charge the IPHONE on the Soundock original.
Bose Sounddock failure
You probably have a broken docking connector or bad power supply. Contact www.invebo.com to get a replacement board. It takes minutes to fit. They also sell the USB charge upgrade to enable you dock to charge the IPHONE on the Soundock original. Try the PSUif you can. The click is the PSU shorted that can be caused by a fault n the sound processor. Invebo will repair it for you too.
1helpful
2answers
Bose Sounddock won't play iPod touch
I put my new iphone 3GS on my sounddock 2 and it worked for one track. The whole sounddock has now totally died. I've tried it with 2 other ipods and still not working and changed the fuse in the plug. ...
1helpful
Will a dead battery in a Ipod play in a bose soundock?
Well with a dead battery it is always best to get it replaced. However, your docking station, or a wall charger, or computer, should all power on the ipod..
If you are interested in purchasing a new battery for your ipod, I would suggest going to the website listed below to do so. It is fairly affordable. Around 45.99
www.iPodbatterydepot.com
2answers
Bose soundock will not play ipod
Check the power in the back, and check the connector, where the ipod plugs in. Usually that part breaks. Or you have to buy a new part from ridax ($50 +) But I'm currently buying broken sounddocks, so if youwant t
Top Bose Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
