Question about Emerson Black Microwave Oven
MW8992SB 9v 0.9CUBIC FT EMERSON MICROWAVE PROF, IT IS NOT STARTIGN UP? WHAT IS WRONG. EVERYTHING ELSE SEEMS TO BE WORKING CLOCK ETC.
Posted by sgarwood9g on
specialistel
    Brigadier General:
  • 8,909 Answers
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
YOUR SAFETY IS PARAMOUNT
This is a job for a professional but if you are safety clued up, here's instruction.
Make sure the !!!!any capacitors are discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Posted on Mar 07, 2011
Testimonial: "Thanks so much for the feed back... i will copy it and call a repair man. Thanks again. SHARON"
No Light and the turntable is not working
Open your microwave completely unscrewed but make sure it is disconnected from the power; check all the other fuses inside, if it doesn't fix the issue then take it to a pro to get this fix.
Jan 03, 2014 | Emerson MW8102SS 1100 Watts Microwave Oven
I have an Emerson 900W Microwave Oven, Model #MW8992SB. Def1 stays on continuously. When I hit "stop, clear" it beeps off and then beeps "Def1" immediately. Then eventually I am able to hit "1" or "start"...
So many microwaveso have issues because there are millions and millions of them. You need to study the booklet and set aside some time to explore it. Write down what you do and assess it. In about an hour you'll figure it out. Download the booklet! Ovens are similar with various timers. It gets complex owing to the size of the electronic controlsystem.but totally fixable!
Jan 15, 2018 | Emerson Black Microwave Oven
LMA1560SB microwave--everything works fine (lights, clock, turntable) except does not heat food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 16, 2011 | LG 1.5 Cu. Ft. Full-Size Microwave - Black
Emerson microwave MW8992SB Just nothing. No clock no light. worked last night.Has electricity to it.
The main fuse has blown inside the microwave, the most common reasons are, one or more of the door switches is defective, the high voltage capacitor has shorted, or possibly the high voltage diode, and sometimes it just the fuse. I recommend a tv tech or appliance repairman because there are dangerous high voltage present.
Jan 17, 2011 | Emerson Microwave Ovens
How many watts does Emerson MW8675W Microwave have?
Is the cubic foot size of the microwave on the name plate?? It seems that with Emerson the size relates closely to the wattage .. 0.9 cu ft is 900 watts, 1.1 cu ft is 1000 watts .. 0.7 cu ft is 700watts .. That would be the closest info I can get.
Please vote !!
May 10, 2010 | Emerson MW8675W Microwave Oven
900w Emerson Microwave Oven
I just came on the internet to search the microwave, and mine is the 900W red version and i have only had it-well less than a year, and it just stopped. No noises, just stopped while i was defrosting some chicken. What the heck. Not cool.
Dec 17, 2007 | Emerson Black Microwave Oven
Broken turntable
The owner's manual is online at:
http://www.emersonradio.com/owners/MWO%20manual/MW8992SB-RD.pdf
You can contact Emerson at their number in the manual for a replacement.
I always suggest that people place food (especially popcorn) off-center on the tray (not in the middle) because the heating is better, plus the extreme heat is not always applied to the same spot in the tray each time.
Food placed in the middle will not cook as evenly.
Good luck, and we appreciate your thoughtful rating of our answer.
Nov 17, 2007 | Emerson MW8987B/W Microwave Oven
Emerson Black Microwave Oven Logo
417 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
