On the left side, near the pichup roller, of the tray there should be a "flag" hanging down in the elips hole. See if it is hanging down or stuck in the "up"position. If so pul it down and the machine should work fine again.
System incompatibility issue. I have mo bo that will not work with XP but works fine with Win 98. Happens and nada you can do about it except get mo bo that works.
Hello,This always happen when the processor is bad or faulty. when the system is working, check if the processor fan is working too, if the processor is working that means the CPU is faulty.leave the system open and power it on to see if it will hang.
I had been moving some furniture and I think I inadvertently knocked a usb cable loose. I also had it going to a hub that was possibly not working. when I made sure everything was hooked up correctly and directly, it was working fine again. I hope this helps someone.
I need some help. I just bought a new hp netbook, but when I try to turn it on.....all I get is a small box saying: When trying to update a password, this indicates that the value provided as the current password is not correct.
What does this mean, I tried to reboot and everything but nothing happens, the computer keep restarting and I keep getting the same small box. Please need some advice and help
1.If VGA onboard on your Motherboard Pl try Extranal VGA cord.
2.Apply Heatsync paste Properly at CPU.
3.Check any bulch capacitors on MB.
4.check CPU Fan and change it.
Was this solution is use ful Pl appreciates my ratings.
similar issue: my notebook hangs instead of restarting. i thought its the usb2.0 of my rather old(3yr) notebook. but i bought a cheap usb box for my old 120G hdd and it plug-n-play like a charm on the same old notebook/same usb port. quite frustrated with this Lacie 500G beast.
so i ended up backing up my notebook using the 1-click backup of Lacie but using my old 120G hdd instead of the new Lacie500G. but then, search as i would through the Lacie documentation, i see no mention of how to restore the data... still looking...
This happens to me on occasion with several brands of switches. I?m not sure what?s happening on the inside but what you in essence need to do is the equivalent of a cold-boot. That means powering down both PCs and turning of any power supply the switch may have attached to it. You?ll know when you?ve been successful when all of the switch LEDs are off.
Again this is and old question and it primarily intended for the person who is researching a new issue
