Question about Lands Phones
I need to change a name on a particular internal extension line, but I dont have a code. How do I do it. It's for an NEC Dterm Series i
Posted by pwheeldon on
Anonymous
    New Friend:
  • 18 Answers
To change the name I believe you have to go into the voice mailbox for that extension, and change the recorded name.
Posted on Mar 07, 2011
How do i change the extension name on the display of NEC Dterm Series i?
Which NEC system is the Dterm Series i connected to? Normally you change the ext name in system programming, but I need to know which system it is.
Oct 14, 2016 | NEC Lands Phones
Trying to call an employees extention and it goes straight to intercom and he cant recieve any incoming calls on a dterm 80 phone
Not too clear on what's happening. Maybe the phone is set to call forward all. Usually CFA code is 41 plus ext. If the user happened to dial 41......, but forgot to dial 9 first for an outside line the phone could be forwarded to the twilight zone. In this case, dial 42 to cancel CFA, problem solved. If do not disturb in on, code 40 is the cancel code. This depends on your codes being at default, if your office codes were changed, say to make room for 400 series extensions, then who knows what will set and cancel CFA or DND. If you want the phone to ring instead of voice announce on internal calls, I'll have look for that later. I know it can be done in programming, but there's probably a code so you can do it yourself.
Apr 14, 2014 | NEC Dterm DTP 16D-1 Corded Phone
All extensions ring on oncoming call on NEC Dterm series i
.. I don't have a solution, I need a solution.
NEC Dterm Series I, through internal calls my phone flashes notifying me that I have a call coming through but it doesnt ring. I have tried the volume key ^, that didn't work. Can anyone help me?
Aug 27, 2012 | NEC Dterm DTP-2DT-1 Phone
I need to change my display name for my Dterm 80 phone. I also need to add a name and extension
you need to access program mode on the phones.
mb 4-18 is name assignment
new station is 4-10
ldtsnj.com
May 11, 2009 | NEC Dterm DTP 16D-1 Corded Phone
How do you change the hold music on an NEC dTerm Series i ?
If you are listening to internal music on hold, it is done at the PBX. A general user can't change it.
Apr 02, 2009 | NEC Dterm DTP-2DT-1 Phone
Name Display NEC DTerm Series i
It is changed via MAT or MOC programming. See you PABX Technician.
Mar 27, 2009 | Lands Phones
NEC dterm series II phones-name desplay
This works on the series E phones. It may or may not work on the series II.
  1. Press the Speaker key (do not use the handset).
  2. Dial the Name Assignment access code and wait for the special dial tone.
  3. Using the key pad spell the name. Press each number until the letter appears.
  4. When the correct letter is displayed Press the HOLD key. Pressing the HOLD key will lock the letter in place and advance to the next position.
  5. Repeat steps 3 and 4 continue to spell the name.
Pressing the TRANSFER key will change the current letter to lower case.
Example to enter the name “Pat” press:
77 HOLD 22 TRANSFER HOLD 88 TRANSFER HOLD
Apr 16, 2008 | NEC Dterm DTP-2DT-1 Phone
Change the Extension ID To New Employee Name
To change the names on the NEC Dterm 80.
Feature, Conf, #, 0, *, 8974, LINE 4, 18.
Select Conf to go to the name you want to change.
Select Hold to erase the characters.
Select Transfer to save it.
Once you save, make sure you go back to "18".
Mar 11, 2008 | NEC DTU 8D-2 Corded Phone
Internal Call "Voice Call" and does not ring
You can toggle each individual phone extension as to whether or not it recieves a "voice" call or a "ring-first" call.
At the extension, press "SPEAKER - 60" it will display the mode. Press the * (asterick) key to toggle between the modes. Then press SPEAKER again to set.
Nov 30, 2007 | NEC Dterm DTP 16D-1 Corded Phone
Lands Phones Logo
414 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
