Question about Emerson (025806803716) Wine Cooler
What is the lowest temp that the cooler has. - Emerson (025806803716) Wine Cooler
Posted by janetdavis59 on
Yanick Martin
    Sergeant:
  • 232 Answers
If you got this new, You should have a manual with the hi-est and lowest temp setting in it...If you do not have the manual than you can Google the same question on google search and get a manual,or a forum where they talk about this model.
Posted on Mar 07, 2011
What does LL mean on the temp on the wine cooler?
It probably means "low level" ie the lowest level of cooling.
For a wine fridge this should be no cooler than 10 degC or 50 degF
Mar 29, 2017 | Ovens
Why does my Igloo FRW700 wine cooler always cool to 0 Celsius or 32F if you prefer regardless of the temperature setting?
It sounds like your temperature control is not functioning correctly. Most temp controls still have a small mercury switch somewhere in the cooling circuitry. I would hazard a guess that if you can turn the dial to different temp settings and it always goes to freezing at 0C or 32F that your temp switch is either bad or the mercury switch (which tips forward or back depending on the setting to make contact and start the compressor) is stuck somehow so that it always sets to the lowest possible setting for your Wine Cooler. Without actually looking inside and testing circuits, that's my best estimation of your issue. Hope that provides you with a starting point to talk to someone who can help you repair it.
May 20, 2014 | GE Profile 26.6 cu. ft. Side-by-Side...
Purchased second-hand and need a operating manual. Where do I find them on internet? Also, the only way to lower the temp. is with a remote control. Each time I press the down arrow to lower the temp,...
The model you have has been discontinued. However, if you call Haier Customer Support
1-877-337-3639. They should be able to provide you with an Owner's Manual via email attachment.
Hope this helps you.
Jul 21, 2011 | Haier HPRB07XC7SW Air Conditioner
My under the counter refrigerator does not drop the temperture below 41 degrees, Is that the lowest that it drops?
It is quite possible that the thermostat is et for that temp... see if it is adjustable...but that should be very good for wine... it does not need to be colder then that...
heatman101
Aug 05, 2010 | Jenn-Air JWC2450ARS Stainless Steel Wine...
True cooler frezzing kegs of beer
If I am not mistaken, the True line-up of coolers have a temp control on them that is labeled 0-9.
This particular type of temp control is a coil temp control. I measures the temperature of the coil rather than air temperature.
Always set the control to the warmest setting and move it colder by one number at a time until your product reaches and holds designed temp. Do not go by cooler air temperature as there will be a great swing in temp especially if the doors are used frequently. Always temp the product. In the case of beer, your ideal holding temp is between 35-38°.
If you set the temp control to the warmest setting and the cooler is still freezing product, you will need to have the cooler serviced be a refrigeration tech. It will most likely be a bad control but there may be underlying problems.
Jan 08, 2010 | True TBB-2 Beverage Cooler
Replaced control on u-line 75WC wine cooler now runs constantly
If the sensor of the thermostat is not on the evaporator plate then yes the thermostat will never be satisfied. Because it is not reading air temp only the evaporator plates temp. should be clamped onto the bottom of plate.
Sep 13, 2009 | U-Line 75WC Wine Cooler
Power vent 50 gal tank flashing code 2-3
1. Turn off power vent blower and set water heater temp to vacation (lowest temp)
2. Turn on power vent blower
3. Turn the water heater temp from vacation (lowest temp) to hot (highest temp) four times.
4. Set the water heater temp to normal
Aug 21, 2009 | Rheem Water Heaters
Cooler is freezing my Beer!!
Could be the thermostat isn't working and the unit is just running and running all the time. To me that seems the most simple explanation right now. Can you check the temp inside when on the lowest setting for a day, then turn it up to the highest for a day and see if there is a huge difference in temps? Does the compressor motor ever turn off or does it run continuously? Suspect that t-stat...
Nov 20, 2006 | True 3 Keg Direct Draw Beer Dispenser,...
Emerson (025806803716) Wine Cooler Logo
192 people viewed this question
Top Emerson Furniture Experts
John Tripp
John Tripp
Tom Chichester
Are you an Emerson Furniture Expert? Answer questions, earn points and help others
