Question about Whirlpool GU2400XTP Built-in Dishwasher
Whirpool dishwasher quiet partner 2 clean light blinking wont cancel or run a cycle
Rick
  • 552 Answers
press normal heated dryer normal heated dry normal the dishwasher should reset and start. You will need to check the heater this happens because the heater normally fails. Let me know,
http://www.appliancerepairlesson.com/
Posted on Mar 07, 2011
  • 4 more comments
  • k9tasha Apr 07, 2011
    Awesome!! I have a quiet partner 3 and this worked. Thank you so much. I will check the heater on mine as well.
  • analyn1955 Apr 07, 2011
    I also have a quiet partner III and it worked !!... Thank You !
  • Joe Smith Dec 10, 2011
    I have a Quiet partner II, was frustrated, very frustrated, and this worked. Bam! frustration gone. Thanks.
  • mcdanielstei Dec 18, 2011
    I have a whirlpool quite partner II and OMG, that just worked!! Mama fixed the dishwaher, Oh yeah!
  • onustack
    onustack Aug 15, 2012
    Thanks! Your Normal, Heated Dry, Normal, Heated Dry, Normal worked on my unit!
  • kim werst
    kim werst Jan 10, 2014
    Thank You, reset!
Anonymous
    New Friend:
I have a whirlpool quiet partner 1 and the clean light keeps blinking andd it won t reset itself what can i do to fix the problem?
Posted on Mar 28, 2011
My quiet partner 111 whirlpool dishwasher is flashing clean
Hello.
Manufactured by Whirlpool, Kenmore dishwashers have an electronic control panel that must be unlocked in order to set or make changes to your dishwashing cycle. If an error light is blinking on your dishwasher's control panel, the panel must be reset before you can gain access. Blinking lights on your dishwasher control panel may signal a mechanical problem that needs to be repaired. If the lights continue to blink after you've reset the control panel, contact Sears to service your Kenmore dishwasher or consider troubleshooting the appliance yourself.
1Press and hold the "Heated Dry" button on your Kenmore dishwasher for four seconds to unlock the dishwasher control panel.
2 Press the "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" buttons one after the other, in fairly quick succession.
3 Wait for the dishwasher to run a short diagnostic test.
4 Press the "Cancel/Drain" button at the end of the diagnostic test cycle. This should reset the control panel on your Kenmore dishwasher.
Thanks.
Nov 04, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
The "clean" button is flashing & none of the other cycles work.
heated dry and high temp wash
toggle till all the lights light up
then hit cancel
you should be able to turn dishwasher back on
you probably have a bad heater
is it flashing 7 times
take kick panel off and look to the rear of the dishwasher
is anything burned
if the clean light keeps blinking replace your heater
Feb 09, 2010 | Dishwashers
Whirkpool quiet partner 3 dishwasher status stuck on clean. If I press cancel it goes into a 2 minute drain cycle, but there is no water in it. It will no reset or start....just blinks clean.
if you have a heated dry option and normal wash option push those buttons back and forth three times all the lights will come on reseting the board..
push cans. and your done
if this happens again that means you have a bad heater or bad board
Aug 21, 2009 | Whirlpool Dishwashers
Constant flashing clean light
count the blinks shoud be 7 times it blinks then a pause if it does that its a heat circute problem need to check the heater and replace the controls
Jul 13, 2009 | Whirlpool Dishwashers
Whirlpool quiet partner III clean light blinking green
you have to hit heated dry and normal and toggle these till all the lights light up. then hit cancel . you are going to have to turn the power of and slide the dishwasher out and look directly behind the dishwasher you will see that a wire off of the heater is more than likly burned of repair the wire you should be fine. replug dishwasher in after wire is repaired. if you do not have a burned wire you have a bad heating element replace the element.
Apr 14, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
Whirlpool Quiet Partner 980
Bad control board ,replace it.
May 26, 2008 | Dishwashers
clean light blinkin???? ry pushing the sanirinse-heated dry--sanirinse--heated dry. tha tshould put in diagnostic mode, there also should be a trouble shooter underthe lower acess panel
Apr 09, 2008 | Dishwashers
Whirlpool gold- quiet partner III
An angel of mercy on another blog posted this solution and it worked for me as well. My Whirlpool Quiet Partner Dishwasher would not work due to the CLEAN light flashing in 7 interval sequences. I followed these steps and my dishwasher is not working perfectly...hope it works for you:
"Well for mine which is a Whirlpool Gold Model # GU2400XTPS3, I found the seq of buttons that I had to push to reset the curcuit board. I think it may of been in this forum somewhere. But I had to push - Sani Rinse, Heated Dry, Sani Rinse, Heated Dry, and then the dishwasher went through it's diagnostic cycle and then after that the light stopped blinking and the dishwasher works great. Supposily, there is a Product Tech Sheet behide the kick panel of every dishwasher, but mine was gone so I had to find the information on the internet. You might want to do a serach for the correct seq of buttons you have to push to reset the curcuit board. If you know for sure that the heating element is bad, you will have to order one. "
Mar 04, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
4,186 people viewed this question
Top Whirlpool Dishwashers Experts
Michael Thomas
Michael Thomas
Mike
Marvin
Marvin
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
