I am trying to pair a new Samsung C3110 which "sees" the T305 and then asks for a code. If I guess a code it replys "Unable tp pair with Motorola T305". Bluetooth is on with both phone and the T305 and the T305 works perfectly with my other phone. Please help. [email protected]
Hold the power button in on the speaker system until the indicator light turns purple. Have your Iphone scan for bluetooth devices and select the T305. The first time it connects it will ask for a security key which should be 0000. If that doesn't work try 1234 as well.
At that point it should pair successfully and you should be good to go.
Please leave feedback if you found this helpful. Thanks.
What is a t305? It must be a device which can type a passcode. A passcode is a number that Bluetooth devices use to confirm that it is safe to connect. If you pair two mobile phones, it asks for a passcode. You enter it in one and then the same in the other.
If the t305 is not a device which can enter a passcode, then you need to refer to its manual to see what to do if the phone asks for a passcode.
switch on the bluetooth on both the device and then select option "shown to all "now starts searching from any one mobile.now you will see the name of other mobile ,now select option button and then it will ask you to pair..just select pair option and then it will ask you for a code type any code like 0 ,1 ,2 ,now other device will get a message that mobile no1 wants to connect .click on to accept and now it will ask you for a code, here you have to enter the code which you typed at mobile no1 .enter the code in mobile no2 and your mobiles will get paired
i tried my level best to resolve the issue.it was not my problem that i was not getting reply message from you........but anyway ...if you want further help let me know........i am still online to assist .........
thanks for using fixya technical support.you have a wonderful day
do not just switch on the t305 .hold the on button down for at least 10 secs. much longer than the usual switch on .it will go through the normal on sequence to the pairing signal mode.do a search for device .when found pin 0000 as you have already done.
