Acer AL1715 (Black, Silver) 17" LCD Monitor Logo
Posted on Mar 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am unable to turn the screen off and the Menu button, actually, none of the buttons on the screen works. It constantly shows the Volume in the centre of the screen and I cannot remove it. Please help! I have turned computer off, unplugged the screen and everything attached and it still does it.
Anonymous
Level 2:
Scholar:
  • Expert 80 Answers
  • Posted on Mar 07, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
80
Questions
0
Helped
25002
Points
237
If none of the button are working then it could mean that one of the buttons is stuck or there is an issue with the board on the monitor itself.
Unplug the monitor from power and the computer. Make sure none of the buttons are stuck down, plug only power back in to the monitor and see what it shows. Plug it back into the computer and check to see if the problem returns
How do i get a default pin code for my samsung SCH-M828C
Default code should be 0000, 1111, 12345.
If none of those work and you are unable to use the device or would like to wipe(erase) the device, look below.
If you are trying to erase everything from the phone: Pull out the battery or power off the phone, Hold the Volume up and camera button, while holding both buttons, press and hold the power button until boot., after the nudge or as soon as the Samsung logo shows, let go of the power button(keep holding the other 2(volume up and camera).
When a little android with something on it's chest, let go of the buttons, wait until the menu shows up and use the volume buttons to move down to wipe userdata, press the power button to select the option highlighted.
4answers
My volume display stays on
The Tv needs to be serviced by a technician.Probably there is a problem with the circuits inside.
I have a curtis flat screen and when i turn it on the volume automatically goes to zero. I press the volume to turn it up but it just goes back to zero. I press the menu button and it just cycles through...
Take the batteries out of the remote and turn it on manually see if that helps............ you might have a stuck remote.
Also make sure none of the buttons got stuck in the pressed position......
I have a PANIMAGE media tablet 7'' 2GB/GO, model numberR79RT2W5.. it turns on and thats it, it shows a constant blue line centered at the bottom of the screen, i can press the menu button on the top of the...
You'll need to do a factory reset:
1. With the device off, press and hold Volume Up and Power.
2. Release the Power button when you see the logo, but continue to hold Volume Up until the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4. Press Volume Up continue.
This will reset you device to factory settings, however anything on your SD card will still remain.
At this point you will need to start fresh as if you just bought the device -- register with your email address, etc.
1helpful
Tv volume stuck on max, volume + signal stuck, button is fine.
The problem is on the board with the controls----if remote receiver is not on same board disconnect that board--if it is unsolder the vol and channel buttons--the front buttons have priority over the remote--buttons will look fine but the switch under each will be your problem---better hope it is as only other cause is a microprocessor gone mad.
If you have a Ohm meter I can tell you how to prove this--going to have to get at the buttons--if you want to prove it is or is not a issue with the micro switches you are going to have to unsolder or test them.
SD TECH
1helpful
2answers
I have an Acer H243H widescreen monitor; it has speakers built in. My problem is that the Volume controls constantly show up on the screen and I am unable to get it to go away and stay gone. The touch...
When this occurs with mine, I power down the PC through windows and the monitor using the lower right power button, let bot sit for 10 - 20 seconds, then power on the PC and switch on the monitor a second or two later and the icon disappears.
Before I did this I found it would eventually disappear.
Acer support claim the H243H is a touchscreen unit, that's what the icon is all about, buy you must have Vista to use it, not XP.
Volume pop up in the middle of my screen
no photos of said window presented? i cant see them?
must be OSD? the monitor brain on screen display (menu)?
even with the DVI cable pulled?
only a monitor stated, w1907, no PC
some monitors have button lock
read the manual ?oops HP deleted it...
it tells you to push the menu key on the monitor for 10 seconds
and it unlocks. (4 buttons right side left button is MENU)
doom?
that power deal sounds super bad, like the power supply is bad.
if the monitor fails by its self not plugged it to a PC
then the monitors is bad.
try a reset on it? ( power off for 1hr, or off then plug in with power button held? or power on with menu held (wild guesses but common practice)
ok found your manual page 4-8 shows menu page advanced
list line in list factory reset.
but if the keys are dead, and power lamp failing
the power supply is no good or worse. worse is always possible.
and expensive
ever see the support page, read the guides
https://support.hp.com/us-en/product/HP-w1907-19-inch-Widescreen-LCD-Monitor/3709665/model/3709666
its over 10 years old now. 2007?
walmart has larger one for $50
cheaper that parts or repair this.... vastly
1helpful
3answers
Sounds like one of the front panel buttons is stuck in - possibly the volume down button. If no buttons work, this could be the reason why. Just a guess. If they all feel OK, it may still be worth pulling the back off, (Without electricuting yourself -DISCONNECT POWER!) remove the PCB board that has the buttons on it, and see if it turns on without the menu. If so, check all buttons, rare but I have seen one that looked fine but with a multimeter it showed it wasnt working. If the screen still displays the menu, Id say there is a bigger problem... HTH
No menu access without remote
the channel selection buttons are supposed to pressed at the same time. the menu page will appear on your screen, use your volume for moving the pointer. entering using one of the volume button. thanks
Frozen Screen
just simply tack out the battery to turn it off
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
