Question about Samsung ES30 Digital Camera
When I take my SD card out, it still says "DCF
Posted by go_me_the_al on
Anonymous
    New Friend:
  • 32 Answers
Well as long as it works when u put the sd card in then its all good right?
also
  1. DCF Full Error error message. The DCF error message with your Samsung camera nearly always occurs when you're using a memory card that was formatted with a different camera, and the file format structure is not compatible with your Samsung camera. You'll have to format the card with the Samsung camera. However, make sure you download any photos to your computer first.
Posted on Mar 07, 2011
  • John Duffy
    John Duffy Feb 29, 2012
    It still didn't fix the prob. I formatted: NO GOOD!
    I removed the card & turned it on empty: NO GOOD!
    I suspect it's a firmware prob.
    Any other suggestions
My Samsung ES30 camera gives me the DCF Full error message.I tried other solutions ,such as formatting the memory cardd,I even tried a new memory card.Still the message comeup.Who know what to do?I am in...
The manual says: the files names does not match the DCF format. Transfer the files on the card to your computer and format the card.
You tried to format and it did not work. Sure the card is not locked? The lock switch should be up, so the card is unlocked an you must be able to format te card and you should be able to write files to the memory card.
Although the camera is compatible with SCHC I wonder if you did not put in a very big card. Perhaps your camera cant work with 8 or 16 GB. Is surely can't work with SDXC cards.
Did you try a normal SD card, and could you format that one?
Nov 02, 2013 | Samsung Cameras
I have problem with my samsung digital camera always it shows a dcf full error on screen.
Thanks for using fixya!
The problem is from your SD card. First make sure you have copied all the pictures to your computer.
Then, FORMAT your SD card using your samsung camera. (Don't format it on your computer)
I hope this helped you!
May 28, 2011 | Cameras
When I turn on my camera, in the middle of the screen in a black box it says " DCF full error" what does this mean and how do I get it to go away? I have tried resetting my camera and formatting...
Hello
Thank you for using FIXYA!!!
OK, firstly let me state what exactly the error message you are receiving concludes to:
"The "DCF full error" occurs when you use memory card in your camera which is formatted in another camera. The error is the result of improper formatting of the memory card which leads to incompatibility of the card with the Samsung camera."
Now, i the resolution for this specific problem is to format the memory card in the Samsung camera.
I know you stated that you have already formatted the card, but you did not state if you formatted the card in your camera, or on your computer.
Try the above solution and let me know if the problem still persists.
Please do not hesitate to let me know if you have any further questions.
Kind regards
lock123
May 24, 2011 | Samsung S860 Digital Camera
When l take my SD card, it still says " DCF Full Error"
Hello and Welcome
The DCF error message with your Samsung camera nearly always occurs when you're using a memory card that was formatted with a different camera, and the file format structure is not compatible with your Samsung camera. You will have to format the card with the Samsung camera.However, make sure you download any photos to your computer first
Anymore help, I am here to help
Best of Luck
Concerned:
Uxair Shah
Mar 14, 2011 | Samsung ES30 Digital Camera
DCF Full Error
DCF = Digital Camera Full
Usually, that just means you have taken a lot of pictures/videos and your memory card is full.
You should transfer them to a computer via USB or by taking the memory card out and putting it directly into a computer.
If you continue to have problems after emptying the memory card, you may have a faulty memory card.
If you suspect you have a faulty memory card, you might try a different one.
Always try to use a trusted memory card brand (I prefer Sandisk).
Good luck, I hope I was able to help
Feb 28, 2011 | Samsung S860 Digital Camera
When the Camera is turned on it reads DCF Full Error. How can I fix this error?
.try to format both...
remove the sd card on your unit,then insert that to the mmc reader then format it to your pc,,after formatted.,,
open your unit without sd card,,go to menu - setting - format -reset
after that insert it to your unit.,then take atleast 15 shots.,.then turn it off.,.,then open again for you to find out if this procedure will okey.,
Feb 25, 2011 | Cameras
Our Samsung ES30 is showing a DCF Full Error. It is only 1 month old and has a 2gig SD card in it. What is the problem?
Feb 23, 2011 | Cameras
New 4G memory card states full have re-formatted but still shows full. Have tried a 2G card but that is ok to use any ideas please
Your new 4GB card is an SDHC card. The S700 works with MMC and SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. You need to go with cards 2GB and smaller.
Jan 10, 2011 | Samsung Digimax S700 Digital Camera
I have a sd card formatted with DCF
C653 doesn't support either file formats.
So unfortunantly this is not possible using this camera model.
Jan 06, 2010 | Kodak EasyShare C653 Digital Camera
DCF Full Error
I have got a Samsung ES30 Digital camera .Everytime i turn it on it always says DCF Full Error ' which i have no idea means .Please help???
Sep 25, 2008 | Samsung S860 Digital Camera
Samsung ES30 Digital Camera Logo
444 people viewed this question
Top Samsung Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
k24674
Are you a Samsung Camera Expert? Answer questions, earn points and help others
