SMC EZ Connect g SMCWEBT-G Logo
Posted on Mar 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi i bought the smc wireless router and i tries to connect it but i couldnt figure out how to connect it because i have a laptop and my internet is connected from my modem to my laptop but i cant seem to figure out how to connect all of them the laptop and router and modem and i have one openin on each piece like one openin in my router and one openin in my modem and one openin on my laptop sooo please help me i really need wirless internet and i cant figure it out!!!!! help!!!!!
Anonymous
Level 2:
New Friend:
  • Expert 41 Answers
  • Posted on Mar 07, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
41
Questions
0
Helped
5339
Points
125
I'm unsure of the exact part number here but using the model number I checked the manual. This looks like it's just an access point which extends a current network you have. If you only have your laptop, this device and your internet modem it may not give you the wireless connectivity you're looking for. On a normal setup you would plug your modem into a router, plug your laptop into the router and set it up with all your DSL/Cable connection information as well as wireless on/off. You can then unplug from the router and continue life. with this one it's only connecting to an existing setup (another router or another wireless network) and extending it.
If you are looking for a solution to give you a router that connects to your modem and gives you wireless or adding multiple devices on a single connection I would recommend returning this and getting an all-in-one router such as this: http://homestore.cisco.com/en-us/Routers/Linksys-E1000-Wirelessn-router_stcVVproductId97826160VVcatId551966VVviewprod.htm?icid=linksys-specs-e1000-learnmore-btn&src2=linksys-specs-e1000-learnmore-btn
Hi I have an SMC baracade g wireless router and want to connect my samsung galaxy 580 phone to it wirelessly. My computer connection is working. The phone detects it fine and can see that it has WPA/WPA2...
Hi
Try to unplug the power cable of your router for a minute or 2 to re-establish its connection to server. Then try reconnecting to your home network.
Hope this helps
Smc setup cannot be accessed but have network
login to your router and go to wifi and check for the mac address of your laptop, if its require to change anything do it according to it.
To know the mac address of your laptop go to command prompt and type --> getmac
2helpful
Cant connect my SMC to other home computer and have a netgear router, how do i connect my smc adapter
Most hardware like an Network Adaptor you install the software CD 1st. Then plug in the hardware.
Then if you configured wireless (wifi, 802.11) settings on your SMC - you should fine the network NAME when you try to connect. You will be asked for the security key for WEP or WPA or WPA2 that you used in the SMC.
SMC should... then assign IP Settings automatically. If the SMC has Internet, you should have Internet.
My router wont hook back to my laptop and i forgot the password
Go to your control panle then select network connections, if you see your wireless icon, right click it and try selecting repair first.
Also, if the wireless icon is in the lower right of the monitor, right click it and view wireless networks, look for you router, then select it. Then select connect.
SMC EZ Connect 2862W-G does not see Linksys network
It shows that your wireless router and wireless adapters are both working. One thing to try is changing your wireless channel. Since you are already using 11, try maybe 1 or 9. Check if your SMC adapter will pick up the wireless signal.
By the way, how far is your computer (using the SMC adapter) to your wireless router?
2answers
Hooking ethernet to broadband router and cable modem
Hi Sherry - The etherport port on your modem should be connected to the WAN port on your router. You then connect your pc to one of the 4 ethernet ports on the router. If this answers your question PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks.
Jeff
1helpful
PS3 and Laptop issues
the new unit you have is the PS3 is not compatible to the SMC barricade router that you had,, you must find a compatible just only for the PS3 unit,, you can ask from authorization wer you bought it!!
1helpful
Cannot connet to internet
Device communication issue! This sometimes occurs fro many reasons mainly FIREWALLS~ In order to keep this from happeninig you should probably setup a static address on your laptop or if your network has a SSID, it needs to be manually set into your adapter because it is not picking up your network. This often happens when you use your laptop in or on other networks. Easy fix, but need answers to these questions!
Router
click start, control panel, internet options, connections tab, remove anything you see in the "dial up and vertual private network, click on LAN Settings, the only one that should be checked is "Automaticly detect settings, click ok and close all. open internet explorer if problem still there disable firewalls.
contact me if you still have issues.
My router doesnt seem to be Broadcasting the wireless connecition!
it may be that the router is not assigning ip addreses properly, and is duplicating the ip address on all pc's. or you have done the windows diagnose and repair or detect problems. Go to the properties of each wireless card in control panel>network connections and on the TCP/IP line click propertes again and ensure obtain ip address automatically is checked. Also go into the routers settings and ensure DHCP is enabled to give all pc's an automatic ip address. Restart all pc's and your router (not Reset) and you should get renewed ip addresses and be able to connect.
Top SMC Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
