The wrench symbol being lit indicates a problem. Does the wrench symbol blink? when you try to engage the joystick the brakes should try to engage and you would hear them click and the symbol will flash. The number of flashes telling you what is wrong. If the symbol is not flashing and staying on then that also a probem but you can't tell what it is. Either way the chair will have to be checked by a tech that has a programmer to plug into the chair and read the error codes to determine the problem. Check with your provider that sold you the chair to see if they can troubleshoot the chair for you or contact Invacare Tech Support @ 1-800-333-6900 and explain your problem. Sorry I can't give you a definite answer Hope this helps
