Question about EliteGroup V7.5A (K7SOM+ V7.5A) Motherboard
I have a problem with my m/b k7som+ 7.5c. When I press the pwr button everything seems ok, all fans are working properly and I also hear the HDD spinning sound. However there is no POST beep or anything else. The monitor exits the sleep mode (the light turns on but nothing appears on the screen). How can I detect the problem?
Posted by konstanti952 on
  • konstanti952 Mar 07, 2011
    I did all these suggestions (taking out peripherals and RAM, battery for one minute etc but nothing happened) The video card is on-board so I cannot replace it. I also tried another HDD but nothing. I cannot unplug the CPU because it is soldered on this m/b. However thank you all for your time and precious advises!!
Symour
    New Friend:
  • 12 Answers
Hi Konstanti952,
When you started to turn on your computer and work ok and don't give any abnormal beeps (POST) into it. Motherboard works fine as well as components. You can actually test this by detaching your hard disk drive to motherboard. If system works and give display and it's simply looking for hard disk (Boot Failure). It must be your Hard Disk Drive spinning/singing problem. Normally, this hardware component doesn't give powerful sounds, of course you can hear them but in normal mode only unless your hard drive works overload or in full capacity. Sometimes, users may hear knocking or clicking sounds coming out from the hard disk in form of rhythmic sound that starts and stops at random time intervals. It could be the sign that the hard disk is getting old and might quit on you sooner or later. There are several causes of clicking/spinning sound of hard disk drive but most of them are mechanical nature, an electronic failure will usually fry the logic chips instantly, with no warning whatsoever. It is recommended to look for a warning either in the hard disk drive section of the BIOS or during the POST. You can enable SMART to be able to read your hard disk status by main board. If sound you hear is more like a grinding one, this could be the worst scenario. Backup your data immediately if you are still able to access data on the disk. And it might stop functioning anytime. Hard disk drive occasionally produces a spinning sound when it searches for a file which is heavily fragmented. This is caused by the spinning platters as the read-write heads zoom back and forth to access the different sectors where the data is stored. It is important to differentiate this spinning sound from the clicking sound. This spinning sound can be reduced by defragmenting your hard drive from time to time. Hope this helps you. Thanks
Posted on Mar 07, 2011
Flinix Hatsune
    Problem Solver:
  • 5 Answers
Try reseating the RAM and test again. If a no go, check that the RAM is supported by your motherboard as there are some configurations of RAM that the motherboard may not support. If it is supported and you are still stuck, take out the CPU and then reseat that to ensure a fresh connection to the pins. Then turn the computer back on and test. If a no go, check if you changed any jumper pins on the motherboard. I suggest changing them back to the default configuration if you did.
If still no go, I would send the motherboard back or get it checked on if still in warranty.
Have a great day!
rampcs
    Sergeant:
  • 159 Answers
There are a few procedures you can possibly try before replacing components.
I HIGHLY recommend you unplug power while trying these steps
1) Unplug power and remove CMOS battery (usually a small silver circular battery) on motherboard for 1 minuted then reinstall battery and see if it boots up.
2) Re-seat all RAM memory chips. If it doesn't help, then try booting the system 1 memory chip at a time, to rule out a bad stick of RAM
3) If you have a separate video card (not onboard video) then try re-seating it
4) unplug both data and power cables to all internal components (hard drives, CD-Roms, Floppies, etc) and also internal cards and see if it boots. If it does then reconnect one device at a time til you find the culprit
That's pretty much all you can do without swapping out parts.
I hope this help and I wish you luck!!
Regards
1 Related Answer
Anonymous
  • 101 Answers
SOURCE: Front panel connections
You can download the complete user manual in English from the manufacturer's website at this link:)
http://support.asus.com/download/download_item_4.aspx?product=1&model=P4B533&SLanguage=en-us&os=17
The front panel connector pinout is on page 2-33, or page 59 in the PDF file. You should have mor ethan enough information to make all the connections you need.
Posted on Jan 02, 2009
Dvd tray on MDR537H will not open
"...DVD tray won't open until it's set up - clock set and channels scanned..."
Nov 22, 2013 | Magnavox Mdr537h Blk Dvd Hdd Recorder With...
I've got a Alpha 240 e combi boiler..... Everything seems to be wor,kin ok but it won't start the ignition sequence .
could be air presure switch which tells pcb that fan is working and would then bring inn ignition system then main gas valve.Would suggest getting gas engineer in.pommie engineer
May 26, 2012 | Water Heaters
My hp 7060n won't pwr on. I checked the ps it test
I don't think you know what you are doing. No computer will boot without memory! And no mo bo will work without the 4 pin connector being attached to mo bo along with the 20/24 pin mo bo connector..
Listen, keep it simple and just plug in another known working ps to see if unit works. If it still does not work, then your issue could be corrupt bios, bad hard drive, corrupt OS, bogus peripheral, bad memory.
Sep 16, 2017 | Computers & Internet
Am5640 with blue light on, fan, cdr and hdd speens but not display, mouse and keyboard. I checked PS, all tensions are there, new RAM anD HDD. need help, please.
remove ram then switch on pc if u hear rappid beeps then ur motherboard is ok !. if not reset BIOS and on it. if beep comes ur ram is not working properly .
Jun 24, 2010 | Computers & Internet
I try to connect my ECS Motherboard one again but
you may have misplaced the power switch connections which come from front pane to the mother board
there are many of them like pwr switch, reset switch
hdd led etc
check *********** board it will be indicated where to connect the pwr switch pwr led etc
May 07, 2010 | EliteGroup ECS GeForce6100SM-M (1.0)...
I try to connect external HDD hatachi 160 cannot detect.System used xp.
go to start and run. In the command box type
diskmgmt.msc
Click Ok
In the Managament Console you should see your disk. You may need to format
it, or assign it a drive letter.
OR
UPDATE YOUR WINDOWS XP TO XP3
Sep 25, 2009 | EliteGroup K7SOM (K7SOM W/CPU) Motherboard
Toshiba Tecra M3 will not boot, no video, pwr + hdd light on
If not beeps you didn't hear then it's your Motherboard. But, there other problems aside on it.
Laptop maybe have a problem with Power Connection, see to it that your Laptop Power Adapter is supply exact voltage to your Laptop, low voltage power also may cause not to give power your laptop sufficient, if it is does.
And if none of this then it's your Motherboard.
Hope this tip might help you.
Sep 23, 2009 | Toshiba (K000823110) Motherboard
Nothing happens when I press the power button. No
What about the power supply? I bet it's supply's issue. Otherwise make sure that PWR button wires are connected properly and to the correct terminals of the motherboard
Jun 29, 2009 | Intel D915GAG Socket 775 Motherboard -...
My HP Compaq Presario v2000 has new mobo, new CPU
You probably put more than a pin-head size drop of heat grease compound on CPU, thus "bleeding" over on the CPU, effectively overheating processor (very common). In any event, your problem is overheating -that's *the* place to look for now.
gurutim
Mar 18, 2009 | HP Compaq Presario V2000 Notebook
No start-up...
first install your graphic card drivers for sure and second check the jumpers settings on mobo after you let me know again please... and dont forget to use a non usb/wireless keyboard to get in the bios with, sometimes that does it ...?
Oct 21, 2008 | MSI K8N NEO2-Platinum (MS7025) Motherboard
EliteGroup V7.5A (K7SOM+ V7.5A) Motherboard Logo
307 people viewed this question
Top EliteGroup Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
