Question about Canon Rebel XT / EOS 350D Digital Camera
The built in flash does not pop up when I press the flash button
Posted by patfrisina on
abray
    New Friend:
  • 52 Answers
Here's a forum that talks about it: http://photography-on-the.net/forum/showthread.php?t=203699
Hope that helps!
Posted on Mar 07, 2011
60d flash pop up
Mode dial is set to an auto mode or the setting is set for flash photography. Change that and the built-in flash unit won't pop-up every time you press the shutter button.
Feb 28, 2015 | Canon EOS 60D Digital Camera
Nikon D5100 Built in flash won't pop up
Not even when you press the button on the left side of the class? the one with the flash symbol.
Switch on the camera and then press the button.
Look in the manual how you can setup the flash in all other than the automatic mode.
Nov 27, 2013 | Nikon D5100 Digital Camera
When taking a picture is clicks a couple of times does not take a picture and says error 05
Check if something is blocking the in-built flash to pop up or if it is stuck. If the flash is stuck press the flash pop-up button and try pulling it up simultaneously.
May 02, 2011 | Canon Rebel XT / EOS 350D Digital Camera
I bought my new canon eos 60D..i put on external flsah to use..then after i take off the external flash, my camera's built in flash cannot pop up to take flash even i had press the flash button. How?
Hi, What external flash did you use on your Canon 60D? The internal flash will not automatically pop up if in the "Creative Zone" it will pop up with the button in the creative zones (M, AV, TV and P) it will not pop up with the button if you are in the the full auto mode (that's the little green box mode) but, should pop up automatically if required. The flash should pop up automatically in the basic zone for Portrait, close up and night photography, the button won't activate (pop up) the flash. Also the internal flash will not pop up if there is an accessory in the hot shoe. Again what external flash was it you used and did it flash?
Jan 27, 2011 | Canon EOS 60D Digital Camera
Cannon error 05
Error 05 means that something mechanically prevents built in flash to pop up. Ensure that nothing is blocking flash. Switch in P mode and press flash button to pop it up. If it does not pop up - try _gently_ to help it to pop up. If you succed in popping up the flash - check it for any dirt with can prevent flash from popping up.
May 29, 2010 | Canon EOS 400D Digital Camera
Why won't the flash on my e500 pop up when the correct button is pressed or when I try to take a picture that requires a flash?
When you take pictures in AUTO, Portrait, Macro or Night scene mode, the built-in flash will automatically pop up in low-light or backlit conditions. If you want to control the flash pop-up, set this function to OFF.
1 Menu [AUTO POP UP]
2 Use control dial to select [ON] or [OFF].
3 Press the Ok
button.
If you are in any other mode the flash will not auto pop up.
Apr 16, 2009 | Olympus EVOLT E-500 Digital Camera
Nikon D40X built in flash doesn't pop up automatically
This is a common fault with the D40x. You will need to contact Nikon for repair details.
Mar 31, 2009 | Nikon D40x Digital Camera
Canon Camera Rebel XTi reads error 05 and the flash will not pop up
Err 05 means: Something obstructed the built-in flash's pop-up operation. Turn off the main switch and turn it on again.
Prepare to press the flash request button with your left hand. With your right hand, position your thumb and finger to gently pry up the flash head, perhaps using fingernails. Push the button and pry. With that help, it should pop up.
Dec 20, 2008 | Cameras
Canon XTi Built in Flash
I found the answer and fixed my flash. Look on http://photo.net/bboard/q-and-a-fetch-msg?msg_id=00ODWf
This will describe how, if you have been using a speedlite alot, than the little tab under the shutter release side of the hot shoe can get bent down thus constantly pressing down (toward the bottom of the camera) the small button which deactivates the pop-up1.gif flash even when the speedlite is not attached. Just bend the tab up a little with a jewler's screwdriver, turn the camera off and on and voila!! Fixed!!! Dan describes pushing the tab down, but on the xti, the tab needs to be bent up to release the flash deactivation switch and fix the problem. Thanks to Dan D on photonet for saving me a service call.
Feb 09, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Built in flash
Have you given it a gentle press down with the button depressed? This will release it sometimes, Other than that it is a repair shop job or send it back if you are able.
May 20, 2007 | Canon EOS 30D Digital Camera with 18-55mm...
Canon Rebel XT / EOS 350D Digital Camera Logo
64 people viewed this question
Top Canon Cameras Experts
old marine
old marine
halotheracer
halotheracer
Paul Green
Are you a Canon Camera Expert? Answer questions, earn points and help others
