Is your computer detecting it as a new device/hardware? What OS is on your PC? Different OS's word their messages differently BUT all mean the same, i.e. need more info before can suggest a solution. Some drivers need to be sometimes installed manually, just depends on System. If other USB devices are detected by your PC than it is more likely to be the Jaf box or USB cable. That's all I can suggest at the moment.
I DEAR DOWNLOAD NOKIA FLASH TOOLS FROM HERE http://www.mediafire.com/?mudeyqowwc5r868 DOWNLOAD TH FIRMWARE OF YOUR MOBILE FROM(JUST GOOGLE IT WITH RM NO) EXTRACT FLSHTOOLS INTALL JAF COPY THE INF NOK4MODELS INI FILE TO C/PROGRAM FILES/ODEON/JAF.EXTRACT OGM PKEY(DISABLE YOU ANTIVIRUS)INSTALL THE FIRMWARE EXE ON PC NOW RUN PKEY(THE BLEU ICON) AND RUN JAF SELECT BB5 UNTICK THE DEFAULT TICSTICK ONMANNUAL FLASH,DEAD USB AND FACTORY SETTICK ON USE INI AND WAIT UNTILL BOX APPEARSSELECT YOU MODEL IT WILL AUTOMATICALLY SELECT THE FIRMWARE THEN CLICK ON FLASH BUTTON AND CONNECT THE PHONE TO PC WITH OG DATACABLE AND SHOTLY PRESS POWER ON (LATEST NOKIA PC SUIT SHOULD BE INSTALLED)IT WILL FLASH YOUR PHONE AND WILL SET IT TO FACTORY STATE NOTE:- PLZ DOWNLOAD THE LATEST FIRMWARE VERSION.TO CHECH THE FIRMWARE VERSION ON YOUR PHONE DAIL *#0000#
hi dear visit http://www.n5233.tk/ and see the jaf tutorial down the page to reinstall the firmware. before reinstalling the firmware plz check version of installed firmware by dailing *#0000# and install the same version or the above version.DONT DOWNGRADE THE PHONE BY INSTALLING OLD VERSION IT MAY KILL THE PHONE
hi, clean your unit first using lacquer thinner,then blow it slightly by hot air...after doing that clean the pin out because if it water damage it must be corroded...what version of jaf you are using?if your version are not updated ,1202 is a sl3 (simlock 3) unit and not supported by lower version of jaf...much better if you use mx key dongle and ufs box as your interface (do not use jaf as your interface because it would be damage) or cyclone....and here is the procedure.. using easy cable ,connect the phone ,open mx key module ,select ufs interface ,dct4 then bus check...if the info of unit is showed ,put CNT ,MCU,PPM ..before flashing back up your phones rpl first ...then flash the phone...after flashing ,there is a possibility that the phones status is contact service ,dont worry just go to service ,imei and security then direct unlock...but be sure that your mx key is activated by dct4 plus unlocker... in case the phone is not responding after cleaning ,reheat flash ic then repeat the procedure...i hope it will help you ,thanks for trusting fixya.. goodluck..
JAF is the ONLY third party flasher which supports USB flashing. USB flashing is very good and usefull because in case a new phone come out, the user can IMMEDIATELY FLASH THE PHONE, he doesn't need to wait for new F-Bus cable release and to pay expensive delivery costs. The CA-53 cable is included in nearly EVERY BB5 Nokia package.
revive dead phones using simple USB cable CA-53 (no need to buy F-Bus cable and to pay expensive delivery costs)
BB5 models flashing supported using simple USB cable CA-53
the only flasher that can correctly flash Nokia N80 by USB
the only flasher that can repair N91 white screen problem
Note that the JAF box does not unlock BB5 phones . It can flash them only! The JAF box is regarded to be the fastest Nokia Flasher on the market! No extra power source needed, is powered via USB.
$200.00
