The Learning Company American Greetings CreataCard! Platinum 6 Full Version for PC Logo
Posted on Mar 07, 2011
Can I load American Greetings CreataCard Paltinum 6 on Windows 7?
scottdickey1
Level 1:
New Friend:
  • Contributor 17 Answers
  • Posted on Mar 07, 2011
scottdickey1
Contributor
Level 1:
New Friend:
Answers
17
Questions
0
Helped
3392
Points
46
Yes, almost all software is backwards compatible, it's when you buy software that requires a more updated OS where you have problems.
How can I load CreataCard Gold 2 on windows 7
I have American Greetings Creata Card Gold, which my computer states that it is not compatible with my program, is there an updated program?
CreataCard Platinum 4 is it copattable with Windows 7 ?
Sorry, CreataCard Platinum 4 or 8 is not compatible with Win 7.
2answers
Is there an American Greetings Creatacard for windows 7
Ok after days of working with this on windows 7 32 bit. I have found that having anything pluged into the speaker jacks make it crash. with the error. you that are having problem try and unplug your speakers and see if it wor
American Greetings Creatacard Silver 5.0 will not install in vista or windows 7
Easiest way to try to solve that is to do the following. 1. Go to My Computer and find the cd/dvd drive with the install disk in it. 2. Right click and select explore. 3. Find the installation file 4. Right Click and select properties. 5. Select the compatability tab. 6. Under Compatibility mode check the check box for "Run this program in compatibility mode for" 7. In the drop down menu select windows 98
Select the settings and visual theme settings to match the program specs. You may need to repeat this process after the install to allow windows to open the program. Follow the same steps but look for the program file under c:\ program files.
I have American Greetings CreataCard Platium 7 and would like to uninstall it to put a new one on. My computer said it cannot find the file. Can you please help. I have tried to remove it and it want let...
Hi! There may be a missing file or you didn't load perfectly! check CCleaner software, load it and then head for "uninstall" button and select what do you want to remove it, don't worry and have fine
Top The Learning Company Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a The Learning Company Computer and Internet Expert? Answer questions, earn points and help others
