Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
SOURCE: my dream maker spa does not work. there is
open control panel will see a small glass fuse replace if blown if 220 volt check that getting power on both lines
Posted on Nov 04, 2009
SOURCE: How do you replace a flow switch in a spa, or hot tub
turn off the power to the spa. remove the cabinet under the topside remote to expose the equipment compartment. You should see the flow switch, it's usually a threaded 3/4" plug with a single grey wire coming out of it. Most of them are threaded into a tee or a special transparent fitting. If the water level in the spa is above the flow switch, you may have to drain the spa down unless you're very fast about getting the new switch in. Unthread the old switch and thread the new one in. Follow the wire on the old one to the spa pack. You'll have to remove the screws on the cover to expose the circuit board. Follow that wire into the spa pack to see where on the circuit board that it is plugged in. It may be good to run the new wire to have in place as soon as you unplug the old one you can install the new one with no question as to where it plugs in.
Reinstall the cover on the spa-pack and turn the main power back on. Make sure that the arrows on the new flow switch are facing the correct direction (direction of flow). Once you have the spa on and it starts back up, run everything to check for leaks and proper operation. If the flow switch was the only problem, all your faults should be cleared and you should be in good shape. If there are no leaks, you can reinstall the cabinet panel.
The new switch should already have teflon tape on the threads, if not, use teflon tape, apply the tape in the direction as if you were threading a nut onto the threads. You only need a few wraps of teflon tape, too much can crack the fitting you threat the new flow switch in to.
Posted on Nov 07, 2009
SOURCE: I have a Coleman 500 series spa. Recently, I tried
i would drain the whole thing down and run a hose into whatever hole you think it might be in and try to back flush it,....the more pressure from the hose the better. good luck
Posted on Jan 06, 2010
SOURCE: Dream Maker spa - does my dream maker spa 4 person
Depending upon the age, the Dream Maker has a digital thermostat which is easy to change but to be honest I don't think that is the cause of your problem.
Check the keypad connection on the PCB (circuit board).
t could be either the keypad or PCB at fault and withou trying one or the other you'll not be able to determine the problem. My advise would be for you to contact your local parts supplier and ask them whether or not they can supply you a keypad to try with the option to send it back for a refund if it doesn't cure the problem.
A keypad can be trial fitted to the PCB, just unplug the old one, plug the new one in and turn on the power. There's no need to install the keypad to the spa, therefore you wont damage it in anyway.
If the keypad doesn't cure the problem, change the PCB.
Regards,
Ian.
http://hottub.synthasite.com
Posted on Apr 01, 2010
SOURCE: I have a Dream Maker x-spa Dition 4 person spa. i
hi i am having the same problem have you managed to fix it and how any help would be much appreciated thanks joe [email protected]
Posted on Aug 06, 2010
Aug 13, 2014 | Therapure Four Person Inflatable Round Hot...
Jun 30, 2014 | Pool & Spa
Sep 20, 2012 | Pool & Spa
Dec 29, 2011 | Qca Spas Jewel Series Topaz Plus Hot Tub
May 19, 2011 | Heating & Cooling
Jun 11, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
Nov 23, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Oct 31, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Oct 11, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
240 people viewed this question
