Question about Disney DT1300-C 13" TV
The video input channel capability is erased from the auto channel set. How do I replace the video input channel onto the tv. There are only tv channels and no video input. This is for Mickey tv set DT1300-c.
Posted by lisa_john179 on
W.L.
  • 2,509 Answers
Hmmm a wild guess perhaps you should try to add channel 0 (zero)?
Posted on Mar 06, 2011
In just bought new Toshiba regza 40" Lcd tv and auto tuned it, but the picture is terible , snowy and colours are not good, what to do...
Hello
First of all reset the TV. for that
press and hold the POWER button
on the TV control panel for 5 or more seconds to reset the TV.
Then connect the TV tt any source like outdoor areiel or cable box etc, select the appropriate input, and retune the TV. First of all, connect it to an external antenna, and set it to autotune.
You must configure the ANT/CABLE input source before
programming channels (-left-hand column).
If the ANT/CABLE input signal type is set to Cable, the
automatic channel programming process erases channels
that were previously programmed into the TV's memory.
If the ANT/CABLE input signal type is set to Antenna, the
automatic channel programming process adds newly found
channels to the existing set of programmed channels (and
does NOT erase channels that were previously
programmed into the TV's memory.) To remove an Antenna
source channel from the memory, you must manually delete
it.
To tune the TV to a channel not programmed in the channel
memory, you must use the Channel Number buttons on the
remote control.
Programming channels when the ANT/CABLE input is
configured for Cable will take substantially longer than when
the antenna input is configured for Antenna. This is normal;
however, once channel programming is finished, you should
not have to repeat the programming process again unless
your Cable TV service lineup changes significantly.
Find out the received channels are clear or not. If they are clear, your TV is perfect, and the input device you connects ot the TV is faulty. OK.
Feb 16, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Hit the reset button on remote and now tv is not finding any input signal sources. I have checked the connections and everything is the same as before so tv will not do anything. Also not finding any...
hi,
when you press the reset button the tv has gone to factory setting. All the settings made by you have been erased when you rested the tv. you have to set all channels by auto tinning your tv. also you have to set picture setting according to your preference, because the tv is now in factory default setting.
ok
Feb 14, 2011 | Sanyo DP32746 32 in. LCD Television
What channel does video player work on?
your line in or front RCA yellow/white/red cable input is usually defaulted to channel -1 and is accesible by either pressing the tv/video button on tv or remote or sometimes by scrolling down channels past 1
Mar 30, 2010 | RCA 20F424T 20" TV
Sony KP-53XBR45 rear projection TV: Coax input Selector Antena part on rear has the AUX input 'male' connector but the TV/Cable 'male' connection end is missing. Is there a way to use the AUX or any other...
You can replace the connector or if you have a cable box with audio and video outputs on it---connect them into one of the sets of jacks on the back of the set--switch to that input and change channels with the box----you can also do the same thing with a VCR--hook the cable into it and use its video and audio output jacks to connect to the video and audio input on the back of the TV.
In this case (the VCR does not have to work except as a tuner) you will go to whatever input you connect to and use the VCR to change channels.
These are a little less easy to use but costs you nothing---I am here to help, if you have any questions or need help let me know.
SD TECH
Oct 04, 2009 | Televison & Video
Video mode on GE 27GT610
Try hooking up the dvd player and turning it on. Then use the setup and add/erase channel feature to look thru all of the channels. On my older GE tv I found that channel 91 was the correct channel for the video input. I saw the logo for the dvd player on this channel. I just added that channel and now it works. Your channel might be different.
Feb 22, 2009 | GE 27GT616 27" TV
Cannot find AV Channel on new Goodman LD2245WD to play playstatio
Check the the color system of the tv.if the tv is auto no problem
video out from playstation to video input in tv.if this is made right with proper wire.it should funtion
Please Don't Forget To Rate "FIXYA" Me For The Help
Dec 21, 2008 | Televison & Video
Video channel
if your DVD player supports a HDMI cable a single cable is enough for both audio and video channel.
but both your player and TV must support HDMI.
Aug 12, 2008 | Samsung DVD-V4600 DVD Player/VCR
Akai VSG285 video - I can't tune any TV stations thru to the VCR?
This sounds like a hookup or programming problem.
The typical hookup is cable/satellite box output to VCR antenna/RF input, then VCR antenna/RF output to television input. Since you are able to watch pre-recorded tapes, the latter is already correct. There are other ways to connect, using the audio/video outputs of VCR to audio/video inputs of the TV. Older or low end TV sets may not have these connections.
If by chance you are using an outdoor antenna (not cable or satellite) then the antenna connects to VCR antenna/RF input and VCR output as above. You will also need to program the VCR into the stations- most late VCRs will scan for active channels, and program themselves to those channels.
I'm not sure of the capabilities of newer cable & sat boxes, but generally, you had to tune that box to the channel you wanted to record. The VCR is set to channel 3 or 4 depending on the output of the cable box.
Lastly, most VCRs of the last 10+ years require the remote to setup advanced functions, such as timed record, date & channel setup functions. The buttons on the VCR itself only do very basic functions, Stop/Play/Rewind/F-forward/Eject etc.
If you don't have the orig. remote, some universal remotes may be able to do advanced programming functions.
Apr 09, 2008 | Televison & Video
Durabrand dvd/video combi
There could be at least two ways to hook in your VCR. The common way is to hook your VCR inline (between) the sat box output (RF or antenna) and the TV RF/antenna input. This will allow you to play the VCR/DVD & record whatever channel the sat box is set to. I'm not real familiar with the newer sat boxes, but I assume they output one channel at a time, thus, you can only record that channel. On the older cable or outdoor antenna systems, you could record one channel while watching another. Perhaps some sat boxes have this capability. You might do a Google search with the box Model number to see if an online manual can be found. The other hookup possibility is if your TV set has audio/video inputs & outputs. Hook these to the matching input/output of the VCR/DVD.
Sep 30, 2007 | Televison & Video
Disney DT1300-C 13" TV Logo
523 people viewed this question
Top Disney Televison & Video Experts
Demonic-2011
Demonic-2011
Lee Hodgson
Lee Hodgson
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
