Question about Pitney Bowes 9920 Plain Paper Fax
Pitney bowes 9820 fax machine is popping up error 50 check printer what might be the problem
Posted by r_mcbird_692 on
evan89
  • 356 Answers
Error 50 is a service error and you will need to contact your local computer repair or go to their site and talk to customer service to get someone to fix this for you.
Hope this helped
Positive Feedback ALWAYS Appreciated :)
Posted on Mar 06, 2011
1 Related Answer
Nike Merritt
  • 149 Answers
SOURCE: pitney bowes 9820 error message
press function, print incomplete command report, then go to function 4 and use command numbers on report to delete.
Posted on Dec 24, 2009
Pitney bowes fax machine model 1630 has 76 error code, what does it mean
The heater lamp in the fuser is broken. Call 1 800 243 5556 for service.
Oct 19, 2009 | Pitney Bowes Office Equipment & Supplies
Error code 050 what is this? PITNY BOWES 9820
This is a defective laser code. The lubrication in the laser has hardened and the laser cannot turn as fast as it needs to.
Oce is the repair people for PB faxes now. 1 800 243 5556
Oct 05, 2009 | Pitney Bowes 9920 Plain Paper Fax
My Pitney Bowes 9820 fax machine says check printer service due. When I hit the help key it asks for a password which I entered 9820, but no other key after that seems to work
Service due and check printer may be two different problems
check printer may be a fuser or laser problem
service due may be a counter for a ozone filter that needs to be changed to make the EPA ha[[y. If you wait too long to reset the filter counter, it can go to a check printer and cease printing
To reset the counter, press function 99, yes,access code is ***1.yes
press 146, yes, then press 1 to reset, press yes. press stop to exit
Sep 14, 2009 | Pitney Bowes Office Equipment & Supplies
Pitney bowes 9820 error message
Jun 01, 2009 | Pitney Bowes 9920 Plain Paper Fax
New help getting Pitney Bowes 8050 fax machine to work
The code is the same as the model number 8050, Your battery has failed and will not keep it's settings if it loses power.
May 17, 2009 | Pitney Bowes Office Equipment & Supplies
9720 Pitney Bowes Fax - access code has mysteriously been placed
Function 9, access code is 9720, press yes, press no until you get to set access code? press yes, delete code, press yes, press stop. I don't think this manual in online any more, but you can go to www.oceusa.com, go to drivers and support, and look for 9820 or 9800 series. The programming instructions are the same as this model
Jan 06, 2009 | Pitney Bowes 9920 Plain Paper Fax
Pitney bowes 9720 error
I've never heard of that type of error. After going through Pitney Bowes vast database, the searches turned up with nothing worthwhile.
Do you have any other information I can use to further assist you?
Please let me know if this helps. Good luck!
Feb 29, 2008 | Pitney Bowes 9920 Plain Paper Fax
Pitney Bowes 9920 Plain Paper Fax Logo
228 people viewed this question
Top Pitney Bowes Office Equipment & Supplies Experts
Marvin
Marvin
john h
Tom Chichester
Are you a Pitney Bowes Office Equipment and Supply Expert? Answer questions, earn points and help others
