Question about Garden
What kind of gasoline? - Garden
Posted by isidroboni on
Anonymous
    New Friend:
  • 45 Answers
  1. Check your manual for the proper gas-and-oil mixture. For almost all modern two-stroke engines, a 50-to-1 mixture is recommended. That requires about 2 1/2 oz. oil for every gallon of gasoline.
  2. Use only two-cycle oil for your mixture. This oil is made especially for these engines and can be purchased at gas stations, hardware stores or any other place where you buy regular motor oil.
  3. Pour the proper amounts of gas and oil into a fuel can. Shake the can well to mix it.
  4. Label your gas can with the mixture ratio. You can use the same mixture for other two-stroke engines.
  5. Shake your fuel can thoroughly every time you refuel. After a while, the oil will settle out of the gas, and shaking it up ensures that the oil and gas are properly mixed again before you put the fuel into your chainsaw.
Posted on Mar 06, 2011
What kind of transmission ssangyong musso 2001
2.3 Gasoline: All wheel drive, manual 5 speed
3.2V6 gasoline, AWD, automatic 4 speed
2.3 TD All wheel drive, manual 5 speed
2.9 TD All wheel drive, manual 5 speed
Mar 17, 2017 | SsangYong Cars & Trucks
Izusu timing marks diagram
double posted,
year,
spark or cam?
KB tells PICKUP of many kinds and engine and years.
pray tell which one.
hark
1.6 L G161Z I4 (gasoline)
1.6 L 4ZA1 I4 (gasoline)
1.8 L G180Z I4 (gasoline)
1.8 L 4ZB1 I4 (gasoline)
2.0 L G200Z I4 (gasoline)
2.3 L 4ZD1 I4 (gasoline)
2.0 L C190 I4 (diesel)
2.2 L C223 I4 (diesel)
if gas, you have spark and cam timiing.
which is it.
and what engine.
we can not guess any of this... ever.
Mar 27, 2014 | Isuzu Cars & Trucks
What kind of gasoline i need?
According to the manual, "use unleaded regular gasoline with a
min. octane value of 91." You need to mix oil into the gasoline at a rate of 50:1 or 2.5 fl ounces of oil to one gallon of gas. If your saw has little power or is very hard to start, it may have been run with straight gas in which case the piston ring or cylinder or both may be damaged enough to warrant replacement.
Feb 02, 2014 | Makita DPC7311 73cc 14Inch Gas Powered...
Used the wrong gas
Open the gas fill door, remove the gas cap and smell the gas fill tube area. If it has a kerosene like smell then you may have filled it with diesel fuel. If so select your favorite garage to drain the tank and flush the fuel system to remove the diesel.
This vehicle should run on any type of gasoline so I suspect the fluid you put in was not gasoline.
Oct 16, 2013 | 2007 Ford Escape
Truck will not start after filling with gas.wait a few minutes it cranks and runs fine.any suggestions?
Which brand? What kind of gasoline? Some cars doesn't run with all gasoline grades also there is some gas station with poor quality of gasoline.
Happened to my car too, I always use SHELL but one day I stop in the MOBIIL gas station to put some gas, got home and the next day the car won't start had to by the STP aditive to put in the gas tank. wait about 10 minutes and car starts fine.
Another thing is my car won't run good with all gasoline grades
I always use the regular one.
Feb 04, 2013 | 2003 Chevrolet Silverado 2500HD
Ran out of fuel. Filled the car with about six gallons of fuel, but the car will start for split second then nothing..
what kind of car you have, der are two kinds of fuel pump, electric fuel pump and manual fuel pump, electric fuel pump after you filled fuel key to ignition about 1 mins, because the gasoline pump the electric fuel pump, manual fuel pump start your car then wait the gasoline until in comes to fuel filter, if dis are not helpful try to disconnect gasoline hose from carburator, then used compressed air to blow gasoline tank, may be your hose is black of small piece of dirt.
Oct 29, 2012 | 1997 Mercedes-Benz C-Class
What kind of motor oil do i use for a 1996 dodge ram 1500 4x4
according to my Dodge manuals...
10W-30 for gasoline engines
15W-40 for Diesel engines
May 14, 2010 | 1996 Dodge Ram 1500 Club Cab
What kind of fuel does the '06 pathfinder use
For optimum performance, you should use high-test or premium gasoline in your Nissan Pathfinder, as per Nissan's specifications. Using a lower octane gasoline can result in premature ignition which can in the long run damage your engine.
Put premium gas.
Jan 27, 2010 | 2006 Nissan Pathfinder
Recomended gasoline company
Chevron all the way .. packed with Techron which will noticeably clean and keep your exhaust valves and seats virtually carbon free.Pure Techron treament the tank before oil change is a very good thing as well..take it from a guy thats replaced too many exhaust valves from carbon.bottles sold inside...good luck
Jul 01, 2009 | 2001 BMW 325
Garden Logo
261 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
