SOURCE: F2 and F3 error messages on Tappan wall oven model 12-4980 10/03
These are the F2/F3 error codes for a Tappan oven
F2
Oven
too hot
Check Bake function, if OK, replace oven temperature sensor
F3
Oven
temperature sensor open
Check
oven temperature sensor, should
be ~1100 ohms at room temperature. If too high or low, replace
please take the time to give this solution a fix ya rating.
clarkco
SOURCE: The oven beeps and has a error F1
Hello,F1 means Stuck touch pad.
Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be canceled,replace the oven control(also called clock or ERC),touch pad,or both.
Thanks
