SOURCE: set the time on a Armitron WR330 40/8125 All-Sport
Hi jerryurq51,
Please follow these steps to set the time of your Armitron Digital Sport #40/8125BLK Watch.
1. Press the MODE button once. This will put you in the timer.
2. Press and hold down the MODE button. This will put you in the alarm set display.
3. Press the MODE button once more and it will put you in the time set display.
4. Use the ST/SP button to change the blinking portion of the time. Then use RESET button to move you thru the different parts of the time/date.
Hope it helps.
Thank you for using FixYa.
SOURCE: how do you set time on the Armitron Women's Sport
Here is what I found.... Posted by: Joe From Oregon on February 04, 2008 at 09:39 PM
Hi, I have a 40/6753 and here is what I found to set the watch
................Adj......................Start/Stop
...............Mode
.............................EL
Press and Hold down the MODE button until the display starts to flash that you are Adjusting the alarm. If you need to adjust the alarm here ya go :)
Press the mode button again and it switches from adjusting the ALARM to adjusting the TIME.
At this point the display will be flashing the seconds. Press the ADJ button and it will switch to Adjusting the Minutes. Press the AdJ button to advance the minutes.
Pressing the Start/Stop will switch to Adjusting the Hour. Again pressing the ADJ button will advance the Hour until you get to the correct one.
Once correct press the Start/Stop to switch to Adjusting the DATE. Press the ADJ to advance Month and Day.
Pressing the Start/Stop will finally switch to Adjusting the DAY OF THE WEEK. (little circle to the left hand side). Again, pressing the ADJ will advance the Day until correct.
This took me an hour just pressing buttons until I could figure this out. I hope this helps everyone.
Joe
