I have a thumping noise at all speeds. Noisier when turning left at highway speeds. Could that noise be coming fom the cv joints in my front axles?
Clicking noise from front end indicates a failing CV joint . It happens as the out of round balls fall into worn grooves in the joint as it turns The fix is to have them replaced
IF IT ONLY THUMPS WHEN YOUR CAR IS MOVING YOU COULD BE WRITE. PAY ATTENTION TO THE THUMPING CLOSLEY, DO YOU FEEL A VIBRATION IN THE STEERING WHEEL, IF SO THE PROBLEM IS IN THE FRONT END. IF YOU FEEL A VIBRATION IN THE DRIVERS SEAT THE PROBLEM IS IH THE REAR END. YES THE VIBRATION FROM THE FRONT STEERING AND THE DRIVERS SEAT IS A WAY TO TELL WHERE THE PROBLEM IS
2 things I would inspect, your motor mounts, and CV joints. If worn, one or both could cause what your experiencing. See if you can figure out where grinding is coming from, right or left side & check drive shaft CV joint on that side especially. Look close at both boots on them for rips or holes, where dirt has been entering.
P.S. a sloppy/worn CV joint can end up causing irregular wear on transmission as well, so don't let it go too long, if at all.
