SOURCE: Instruction Manual for Fossil Watch
go to fossil .com and click on customer service that is where all manuals are hope this helps
SOURCE: remove the winding stem/crown.
There is a tiny point (end of small metal piece called setting lever) on the left side of the stem (on watch movement, very close where the stem is entering the movement).
You have to push that point down with a metal pin or tweezers. Crown (winder) must be pushed in to normal position otherwise you will not be able to put the stem back properly.
So, do as follows:
1) Push the crown in,
2) Lay the watch down on flat surface and push on setting lever point,
3) While holding setting lever pushed in- extract the setting lever by gently pulling crown out of watch.
Do not forget to rate, please.
-> Go to fossil.com
-> Customer Care
-> Product Info / Watch Instructions
-> Do a mouseover on the various headlines to see the design of your watch.
-> Download desired PDF file
Problem solved. Thank you!
SOURCE: Question:how to set the weekday on a Fossil watch model BQ-9165.
You have to pull out the stem all the way and turn clockwise until you get to the correct day. Hopefully you won't have to wind thru the whole week.
SOURCE: Help! I need instruction manual for Fossil watch
If you go to www.fossil.com you can find the manuals for most of their watches.
Identify the push button that controls the second hand. With the watch face positioned so that 12 is at the top, locate the button on the right of the watch's rim and above the watch stem.
Grasp the watch stem tightly and tug it out, away from the watch rim. Pull it past the first area of resistance, a position used for other settings, to the second stage of resistance where it will not pull out any further.
Press the second hand push button, identified earlier, until it is firmly depressed into the watch rim. Release the button, allowing it to return to its normal position.
Push the watch stem back to its original position tight to the rim.
