Question about Nostalgia Electrics SRCD820 Turntable
I was listening to my record player, and all the sudden it started going really fast. i can't get it to slow down, or sometimes even play at all. when i move the needle over the turntable, it either goes REALLY fast, or doesn't go at all and makes this wierd buzzing sound. how do i fix it?
Posted by toastiwaffle on
Crosley CR40 playing 33 1/2 too fast? What can I do to slow it just a little bit?
I would get a vintage turntable and not a new one inexpensive one. The new record players do not last.
Apr 20, 2014 | Crosley Stack-O-Matic CR40 Turntable
How do i play back a recording i've made? I have the Sansa m200 series MP3 Player
To play back a voice recording, you will need to do the following steps after turning on the player. Press Power/Menu briefly to get the software menu. Press the Repeat/A-B/Down button to highlight the line Play Music and press Select to enter the play back sub-menu. Press the Down button again to go to the line Recordings and press Select again. Use the Down button to highlight a particular voice recording and press Select to start playing the recording.
The manual for the Sansa M200 MP3 player is available as a PDF from the manufacturer here: http://kb.sandisk.com/app/answers/detail/a_id/241 . The details for playing back a Voice Recording are on page 23-24 (24-25 of the PDF). You will need Adobe Reader or a similar program to read the manual.
I hope this helps.
Mar 25, 2014 | SanDisk Sansa m240 MP3 Player
My Teac sl-a100 record player sounds like a chipmunk
hi,
somewhere on that player is a switch for 78-45-33 rpm the speed switch look up around by the tone arm above by where the record goes, it may not be on the front. switch it to the correct record you have 45's are small. 78's are medium and 33rpms are the big records..
jm
Apr 30, 2011 | Teac SL-A100 Turntable
Playback is too fast using Pinnacle Quick start version 10
This sounds like a Frames per second setting issue.
Just a guess, but you recorded at 15 FPS & the player is regurgitating at 24 (or 30) fps.
Sep 04, 2009 | Pinnacle Dazzle Video Creator Platinum...
Recording Speed
the tascam 414 is a 4 track recording studio which uses standard cassette tapes- meaning they only play in one direction, because the tape is full. The 414 records at double speed so that recording fidelity is increased. When you have made a recording you want to mix you then dub your recording though the outputs into another standard tape recorder or whatever you have available, be it a cd recorder or your PC. So, when you listened to your recording on a standard tape player, you were not only hearing it at half speed but you were only listening to 2 of the 4 tracks. The other tracks would only be heard if you flipped the tape over, and they would be heard running backward. I would have though the 414 had a swich to allow it to also record at standard speed to but I guest it does not.
Jan 10, 2009 | Tascam Starter Pack for 4-Track Cassette...
My VCR tapes skip or only play in fast forward
If you are recording the tapes in a slow speed, then I would suspect that the tracking pulse is not being recorded properly. Since this is a new VCR, return it for an exchange. One of the recording heads is bad.
Dan
May 30, 2008 | Televison & Video
Tape plays too fast on slowest setting
The tapes may have been recorded at 1/2 speed or 1/4 speed so they are not playable on this model.
May 16, 2008 | Panasonic RR-830 Desktop Cassette...
Speed
Just had the same problem!!! You have to press FF and Play at the same time to stop the fast play!
This is probably way overdue and you won't even get it, but just in case someone else has this problem...here is the answer!!
Sep 19, 2007 | Dictaphone 2740 Desktop Cassette...
Top Nostalgia Electrics Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Nostalgia Electrics Audio Player and Recorder Expert? Answer questions, earn points and help others
