1. Open the scanner unit.
2. Remove the tape from the new print cartridge
3. The left side cartridge should be the black one.
4. Press down the cartridge levers to open them.
5. Remove the old cartridge and replace with the new one.
6. Close cartridge lids.
7. Close scanner unit and press the "check mark" button to print alignment page.
GaugeMan
Hi, Thank you for choosing FixYa! I have used this unit before and here are the steps you need to follow to replace an empty cartridge on it. 1. Make sure the printer is on. 2. Lift the scanner unit. The print cartridge carrier moves and stops at the loading position, unless the printer is busy. 3. Press down on the lever to raise the cartridge lid. 4. Remove the used print cartridge. 5. Replace it with the new one Note: If you are removing both cartridges, repeat step 3 and step 4 for the second cartridge. For additional instructions and maintenance, follow this link http://www.lexmark.com/publications/pdfs/2007/7300/ug_en.pdf Thank you once again for choosing FixYa! Kindly click on YES to vote for me.
User guide available for free from here
http://www.intel.com/support/chipsets/sb/cs-009236.htm
Go to page 69 for clear instructions
