SOURCE: APEX AT3208S
Sorry to burst the other techs Bubble but APEX does support there sets as well as there customers . I guess the other tech may be well quilifiyed, but NOt authorized by Apex. Apex is just like most other companys. They won't give much support to unauthorized companys, BUT they are great with the consumer. your problem is a vert IC goes bad in these sets a lot as the capacitor off the B+ feed off the HI voltage transformer becomes leaky. A good local shop should be able to fix it NO problem for less the 175 bucks Good Luck. Any problems finding a service agaent call 866-427-3946
SOURCE: Service Mode for Apex PF2720
On a standard PU1 chassis use the following:
1. Decrease the volume to 0
2. On remote press and hold the MUTE button till the color of MUTE displayed changes color. At the same time press MENU on the front of the Tv.
CH +/- to select
Vol +/- to change value
All other chassis:
Decrease the volume to 0, Press mute and video at the same time.
Adjust the TV with menu select buttons on remote.
Exit with the power button.
Hope this helps.
Bill
SOURCE: Can't see the scroll at the bottom of the screen
I was having the same problem. if you turn the vol. down to 00 then press mute on the remote then hold mute on the remote and menu on the tv for 3 seconds you will get the service menu and you can adjust the screen.
hope this helps.
SOURCE: Apex 32 inch tv Model #PF3230
G'day mate
Sounds like the power supply regulation has gone high volts, and the screen is blooming because of it. I suggest getting a tech to look at it, will probably have the usual issues of capacitors failing in the power supply. Cheers
regards
robotek
