Question about JVC AV-27730 27" TV
I have no picture on my JVC AV-27730 tv. Where is the picture tube and can i replace it myself?
Posted by courtneyl570 on
    Top Expert:
  • JVC Master
  • 76,416 Answers
Hello
Picture tubes are available at electronic spare part shops. You have to give them the number and type of the picture tube, to which your JVC TV has. Picture tube, along with its Yoke fittings are integrated, and you can replace it by yoursef at home. Be very carfull in handling the picture tube, as they are highly vacumed, and will explde by hard hits. There will be four seating screws on the four corners of the picture tube, and these slots will clearly alaign if the picture tube selected is orginal number. Diamentions of these holes will be different to spherical and flat picture tubes. So you must first aware of the type of picture tube, which the TV has fitted earlier. OK.
Posted on Mar 06, 2011
How do you set up a remote on a jvc av-27730 tv
Check this site for more details. "Electro-help" is the site name. Search it by google search. You can locate it, either at the bottom of the first search page, or at the top of the second. It is an electronics equipments repair help site in English.
You can get all details here. Pull up older posts. Codes and setup proceedings are described in detail.
Jun 17, 2012 | JVC AV-27730 27" TV
Tip
Here is the manual for the av 27730
http://tv.manualsonline.com/manuals/mfg/jvc/jvc_av_27330_av27330.html?idRes=720867
on Mar 28, 2014 | JVC AV-27730 27" TV
JVC AV-27730: horizontal bright line across screen in the
it could be an electrolytic capacitor or the vertical output I.C. in the vertical circuitry,if you remove the rear cover tap on the board in different places and see if the picture fills out or atleast jitters like it might fill out,then it could be just a cold solder joint,then remove the main board and resolder all joints and this should repair the condition you have
Nov 18, 2009 | JVC AV-27730 27" TV
Dark screen
the sound is locked off the TV good picture
Feb 20, 2009 | JVC AV-27320 27" TV
Erratic problem
need to have the vertical output IC pins resoldered.
Jun 13, 2008 | JVC AV-27730 27" TV
JVC TV
civilman, the first set has either no high voltage or is collapsed vertically, until someone checks for high voltage there is no concrete answer, the AV27730 is vertical collapse from your description, either the voltage to the vertical IC is missing or the vertical IC has failed, not a big deal cost-wise, hope this answers your questions, if not e-mail me back, good luck, BMW Rider
Dec 20, 2007 | JVC AV-27730 27" TV
Abnormal crackling sound from speakers
check the Audio if ic or something gone bad around it. good luck
Apr 28, 2007 | JVC AV-27730 27" TV
Buzzing Noise and TV picture is yellow
Andy, I'm thinking the buzz is from the deflection coil (yoke) on the neck of the tube or the power supply. Probably not the high voltage as you can hear the "buzz". If it's really that annoying, you can take a length of rubber tubing (no metal) and listen to the buzz coming from the chassis kind of like a stethoscope. STAY AWAY FROM THE HIGH VOLTAGE, please. The yellow picture sounds like a blue chroma failure. A tube can be rejuvinated if need be but that's a job for a pro. Hope this helps.
Oct 30, 2006 | JVC AV-27220 TV
Jvc av-27730 27"
One thing you should not do with electronic devices which have a start up proceedure is to turn the power off, and then on again without a wait of about five minutes. Some equipment manuals warn you about this, and specify a longer period. The start-up has to have time to reset. It will be more likely to reset if you do not leave it on standby, and even unplug it. In your TVs case you need to describe the distorted picture as it may give a clue to a fault, or incorrect start-up. The horizontal line indicates the frame timebase had stopped working. No picture could be a fuse blown inside the set, or a timed cutout which may reset after a time. Try after several hours to see if it comes on. If it is just the frame timebase (vertical) it is worth repairing.
Oct 22, 2006 | JVC AV-27230 27" TV
Televison & Video Logo
507 people viewed this question
Top JVC Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
