What model computer are you using? By default Windows should automatically install drivers for you.What model computer are you using? By default Windows should automatically install drivers for you.
You can't post conmments that contain an email address.
if your computer came with a disk the sound drivers could be on it control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustmentsthere or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers hope this helps
Sound on Compaq evo d150. The next site says: http://www.orixrentec.com.my/hp_4.htm
Audio: "Integrated Intel Audio with Premium Internal Speaker".
So there should be a:
* speaker inside
* working on an Intel driver.
When using a PCI-slot for extra sound, the matching driver of the PCI-audio-card should be installed. Of course external powered and wired speakers will be required as well.
at what time after the booting is it shuting down, check the cpu fan , some times system shut down due to overheating, if its ok, then also check some other RAM.
Sorry to say that this board has so many problems associated with it specially the SiS chipsets, that you might be better of replacing them since they should still be under warranty. If you swing swing a replacement of another brand/model even if you have to add a little, that might be a better solution rather than force the issue of repair. Offhand the most that you can really do is check if you can upgrade/update the BIOS and see if there is a significant improvement. Other than that you have little or no other options.
If replacement is viable, try to get motherboards with Intel or Via based chipsets.
Good luck and kind regards.
