Question about Amazon Kindle 1
My kindle wont turn on - Amazon Kindle 1
Posted by lealally on
Robert Hogan
    Problem Solver:
  • 28 Answers
If your Kindle won't turn on, take help of the technicians. Contact Kindle help Number.
Posted on Jun 24, 2020
Jon S
    New Friend:
  • 35 Answers
If the kindle was not dropped or submerged in liquid then it sounds like you simply need a new battery. Here is a site that sells replacement batteries for the Amazon Kindle 1:
Amazon Kindle 1 BatteryThe prices are some of the best around and all batteries carry a 1 year replacement warranty. I hope this helps!
Posted on Nov 14, 2013
Omri Rahamim
    Problem Solver:
  • 15 Answers
If the kindle won't turn on because it was recently dropped or water was spilled on it or something, you should consult your warranty. If this is due to no external event/damage you should call amazon and see whether or not there's an update in software or a bug of sorts. If it's on their behalf you'll get a replacement device. Good luck!
Posted on Mar 06, 2011
Kindle will not shut off-goes to shut off or cancel but wont move. doesnt charge well-doesnt always hold charge
Patricia, Using the power switch, you can forcibly reset your Kindle device. This reset will shut down the Kindle without accessing the shutdown command from within the Kindle's operating system, a particularly useful tool when dealing with a frozen Kindle. To initiate a hard shutdown, Kindle disconnect from its charger, slide and hold the power switch for about 20 seconds. This will force the Kindle to shut down, now it can be restarted normally.
Check links below for charging problems.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Reset Kindle Fire When it Won Turn on or Charge
Troubleshooting Kindle Fire That Won Charge
Kindle Fire not charging
9 common problems with the Kindle Fire HD and how to fix them
Feb 25, 2016 | Amazon Kindle Fire HD
My keyboard is not lighting up
Kindle keyboard is not lighting up
Jan 08, 2016 | Tablets & eReaders
How do I get my kindle to switch off
if it's left turned on, it will turn off when the battery runs out.
Jan 29, 2015 | Amazon Kindle - 6 Inch E Ink Display...
Can't turn my kindle on
Mine done the same thing. I opened up the kindle and disconnected the battery plug for a few minutes. It worked after that.
Aug 06, 2014 | Amazon Kindle Fire HD
There might be some issues with the Battery or the Kindle Device. In the last check the charging port of your device. May be kindle do not charged alternatively you can call the kindle support. Kindle Technical Support Registration 877 690 9305
I have a kindle that wont come on an its charge up
First off, I've had 5+ of that type of kindle. Each time the screen was cracked causing the screen to not turn on. If you see any lines this is definitely your problem. If so, you can either replace the screen or replace the kindle.
Mar 11, 2014 | Amazon Kindle 3G
My kindle wont charge while I'm using it. It only charges when the kindle is off
You didn't specify the model of your Kindle, but the user guide for my Kindle states that it must be turned off to charge.
Sep 21, 2013 | Tablets & eReaders
The kindle won't turn on
It is possible that your Kindle Fire's battery has died. If you noticed the battery life diminishing before it wouldn't turn on at all this may be the case. Here is a site that has replacement batteries for the Kindle Fire:
3555A2L Battery for Amazon Kindle Fire D01400
Dec 31, 2012 | Amazon Kindle Fire HD
`kindle fire
Sounds like your power cord is dead and that it's not charging. If it's new bring it back to the store you bought it from and get a new one.
May 15, 2012 | Amazon Kindle Fire
Amazon Kindle 1 Logo
592 people viewed this question
Top Amazon Tablets & eReaders Experts
Sheldon Dedek
William Alequin
Andrew Taylor
Andrew Taylor
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
