Question about Whirlpool Duet GHW9150P Front Load Washer
The light for "Control Locked" is on and will not
Posted by tscott7000 on
danny Hendrickson
    President:
  • 2,468 Answers
Have you pressed cancel for 3 seconds or more? otherwise press for 3 seconds control-lock and see if it releases
Posted on Mar 06, 2011
Maytag dryer epicz says "controls
controls locked
This feature allows you to lock your settings to prevent
unintended use of the dryer. You can also use the Control Locked
feature to prevent unintended cycle or option changes during
dryer operation.
To enable the Control Locked feature:
Press and hold AUTO DRY LEVEL for 3 seconds. Control Locked
glows and a single beep tone is heard. To unlock, press and hold
AUTO DRY LEVEL for 3 seconds. The indicator light turns off.
Jul 15, 2011 | Kenmore Elite HE4 Electric Dryer
I have a Kenmore Elite HE3 and there is alight on that says "Control Locked" and the washer will not start. I have tried unpluging the machine and pluging it back in but the light is still on....
There's a button on the panel, bottom left, which has small print under it with instructions to press and hold three seconds to unlock the controls.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 27, 2011 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
"Control locked" light is on. Machine will not
Press and hold the button thats says control lock//that will unlock or lock the control panal...If it helped please vote need more help please ask good luck
Feb 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Light reads "control locked" and washer won't work
Please Turn On your washer and hold the END OF CYCLE button for about 10 seconds and that would surely unlock your washer.
Dec 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I cannot use the washer. The "Control Locked"
Hello
Control locked means that the control is locked and needs a Reset, try pressing the END OF CYCLE button and hold it for 15 seconds to solve the problem. Please get back to me if you have any other questions.
Kevin
Nov 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My "Control Locked" is locked. What do I do?
Select and hold the end of cycle button for 3 seconds until the control locked status light goes off.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool Duet Dryer that indicates the "Control [is] Locked. The problem somehow began while I was away over the weekend and it no longer allows me to start the dryer. (I have a total of...
Hello
Your whirlpool duet dryer needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Nov 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
"Control Locked" lamp is lit on the washer. Tried
Press and hold the end of cycle button for 15 seconds this should clear it.
Control locked
Nov 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
CONTROL LOCK and Can't start the GE front load washer - WSSH300GWW
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
May 23, 2008 | GE WSXH208A Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
65 people viewed this question
Marvin
Marvin
Michael Thomas
Michael Thomas
