Your best bet is go to a place where they sell an install stereo systems an ask them . The factory radio on your vehicle is hooked up to the vehicles communication network . Class 2 serial data bus , if it's not done correctly the vehicle will not start an run !
The theft deterrent system is a feature on all base and uplevel radios. There is no need to program a security code into the radio as in past model years. The theft deterrent system now utilizes class 2 serial data to determine if the radio is in the appropriate vehicle. Each time the radio receives the "run" power mode message, it compares the VIN information it has stored to the VIN information received from a module on the class 2 serial data circuit responsible for transmitting that information. If a mis-match occurs, the radio display will indicate to the user the radio is locked. Once this takes place the radio will not respond to any button presses and become inoperative. The two scenarios able to cause this condition are:
A radio is installed from another vehicle.
A module which communicates on the class 2 serial data circuit which supplies VIN information to the radio is replaced and not properly setup with the correct VIN information for that vehicle.
The only way to unlock the radio is by using a scan tool.
The digital radio receiver utilizes class 2 serial data to determine if it is in the appropriate vehicle. Each time the digital radio receiver receives the "run" power mode message, it compares the VIN information received from the body control module (BCM) on the class 2 serial data circuit. If a mis-match occurs, the radio display will indicate to the user the digital radio receiver is locked. The digital radio receiver cannot be unlocked, it must be replaced. The two scenarios able to cause this condition are:
A digital radio receiver is installed from another vehicle.
The BCM is replaced and not properly setup with the correct VIN information for that vehicle.
You can not just replace the radio in this vehicle with another type with out a interface module or something , I forget ! If you go to a stereo place ,where they install radios they will sell you what you need ! The factory radio is hooked to the Class 2 data bus an if other modules on the vehicle don't hear from it , it won't work !
The "Theftlock" theft deterrent system is a feature on all base and uplevel radios. There is no need to program a security code into the radio as in past model years. The theft deterrent system now utilizes class 2 serial data to determine if the radio is in the appropriate vehicle. Each time the radio receives the "run" power mode message, it compares the VIN information it has stored to the VIN information received from a module on the class 2 serial data circuit responsible for transmitting that information. If a mis-match occurs, the radio display will indicate to the user the radio is locked. Once this takes place, a DTC will set, the radio will not respond to any button presses and become inoperative. The two scenarios able to cause this condition are:
The only way to unlock the radio is by using a scan tool. Always refer to the table in this section to diagnose the "Theftlock" DTC for further information.
You better read up on class 2 serial data communication networks . Does supply ACC voltage to anything . Your vehicle has many different control modules , PCM / ECM , air bag , ABS , BCM instrument cluster ,an the radio an some others . If you mess with or ground this wire your vehicle will not start or do anything .
The data link connector (DLC) allows a scan tool to communicate with the class 2 serial data line. The serial data line is the means by which the microprocessor-controlled modules in the vehicle communicate with each other. Once the scan tool is connected to the class 2 serial data line through the DLC, the scan tool can be used to monitor each module for diagnostic purposes and to check for diagnostic trouble codes (DTCs). Class 2 serial data is transmitted on a single wire at an average of 10.4 kbps. This value is an average; class 2 uses a variable pulse width modulation to carry data and depending on the message it may operate faster or slower. The bus will float at a nominal 7 volts during normal operation. Each module can pull this lower during the transmission. The bus is not at battery positive voltage or ground potential during normal operation. When the ignition switch is in RUN, each module communicating on the class 2 serial data line sends a state of health (SOH) message every 2 seconds to ensure that the module is operating properly. When a module stops communicating on the class 2 serial data line, for example, if the module loses power or ground, the SOH message it normally sends on the data line every 2 seconds disappears. Other modules on the class 2 serial data line, which expect to receive that SOH message, detect its absence; those modules in turn set an internal DTC associated with the loss of SOH of the non-communicating module. The DTC is unique to the module which is not communicating; for example, when the inflatable restraint sensing and diagnostic module (SDM) SOH message disappears, several modules set DTC U1088. Note that a loss of serial data DTC does not normally represent a failure of the module that set it.
On some vehicles, if the powertrain control module (PCM) is unable to communicate with the vehicle theft deterrent (VTD) system after the vehicle has started, the PCM will consider the VTD system to be malfunctioning. The PCM will enter a fail enable state and will command the security indicator to illuminate. When the PCM is in a fail enable state, the vehicle will NOT stall or stop running. If the PCM is in a fail enable state when the ignition is switched OFF, the PCM will remain fail enable until communications with the VTD system has been restored. When the PCM is in a fail enable state, the VTD system is NOT active and the vehicle will start. This feature is NOT available on all GM vehicle lines.
You need a interface module for your radio to work . Go to a professional installer place an talk with them . Your vehicle may not have all of these modules , but most .
Class 2 Serial Data Line
The class 2 serial data line on this vehicle is a star configuration. The following modules communicate on the class 2 serial data line:
• The body control module (BCM)
• The digital radio reciever
• The driver door module (DDM)
• The electronic brake control module (EBCM)
• The front passenger door module (FPDM)
• The HVAC control module
• The inflatable restraint sensing and diagnostic module (SDM)
• The instrument panel cluster (IPC)
• The memory seat module (MSM)
• The powertrain control module (PCM)
• The radio
• The radio amplifier
• The rear seat audio (RSA) controller
• The rear seat entertainment (RSE) assembly w/U42
• The rear wheel steering control module
• The remote playback device-CD player w/U1S
• The transfer case shift control module
• The transmission control module (TCM) w/Allison Transmission
• The theft deterrent control module
• The vehicle communication interface module (VCIM) w/UE1
